Old 02-21-2008, 01:35 AM
sirroberts1288 sirroberts1288 is offline
Worst Niose I'v Ever Heard
i have a 1993 s10 blazer.and there is an weird noise coming from my driver side.and when i make a left turn it makes a loud thump,when i turn back it makes the same sound again.my dad said that it is the wheel caliber.
i dont know what it is. i lubed all ball joints.i know it has nothing to do with the brakes or the tires.so could anyone tell me whatt is wrong.
thnks
Old 02-21-2008, 01:48 AM
G.A.S. G.A.S. is offline
Re: Worst Niose I'v Ever Heard
A-Arm bushing, ball joints, stearing stablizer, shocks, anti sway bare link kit(stearing stablizer).
Is this a 4x4?
Old 02-21-2008, 01:26 PM
bozr's Avatar
bozr bozr is offline
Does it sound like a large piece of metal thumping somewhere near the floorboard?
Does it usually happen on low speed turns, especially if there’s a bump?
Is it the kind of sound that makes passengers scared to ride with you?
It’s probably the torsion bar support insulator/s.
They’re a rubber mount, somewhat like a motor mount, that hold the torsion bar support to the frame rails. The rubber separates from the metal and allows the support to hit the frame as one torsion bar loads and the other unloads in a turn.
You can test it with a bar or light pressure from a jack. If the rubber separates from the mount, it needs to be replaced.
Old 02-21-2008, 03:36 PM
thanks for the info i will check all those things to seenif it is one of them.
and no it is not a 4x4
Old 02-21-2008, 04:07 PM
bozr's Avatar
2WD has coil springs, no torsion bar.
Go with G.A.S's suggestions.
Old 02-22-2008, 03:23 AM
Slap me silly.I forgot about the coils. It could even be a coil spring.
Better take a good look at that as well. glad you brought that up.
