Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-20-2008, 10:29 PM
mini man 007 mini man 007 is offline
a clicking sound under the dash
ya that right i have a clicking sound under the dash like the flasher is on but is not but the clicking sound is coming from the flash relay in the fuse box and it is not at all times but more offtin then not it is driving me crazy plz help to stop the clicking soundes lol
opps
1996 burb 2wd and a 5.7
Old 02-22-2008, 04:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: a clicking sound under the dash
The multifunction switch is usually at fault when this happens. Check it and replace if faulty.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-22-2008, 11:25 PM
thank you j-ri is there a way to test that switch or you just change and hope for the best
Old 02-23-2008, 04:57 PM
J-Ri's Avatar
When it is making the clicking sound, wiggle the switch but don't move it far enough to activate the turn signals. If the noise stops, I'd be sure enough to replace it. I've seen several GM vehicles that do this, and every time it has been the multi-function switch.
Old 03-08-2008, 01:03 PM
well ty j-ri it was the flasher arm changed it and it works fine now
