Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 02-20-2008, 08:36 PM
mcdlnwright mcdlnwright is offline
2002 p0141 & p0325 suddely showing up
Ok I had the Van serviced the other day, Just basics and suddenl I have a check engine light
I went to Da zone and it read P0141 O2 sensor
and p0325 Knock sensor
I seem to remember one can cause the other to pop but I cant guess which one. And is there a way to test them to be sure its bad without just replacing it and assuming its bad?
Old 02-20-2008, 09:31 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: 2002 p0141 & p0325 suddely showing up
well the code for the O2 sensor you stated is for a rear O2 sensor Heater ( witch is part of the O2 ) Knock sensor code coudl have been there already, knock sensors do no turn on a check engine light. that is why.
Old 02-24-2008, 08:05 PM
repeat
Old 02-24-2008, 08:21 PM
does anyone know where I can find a guide to fix these?
I have replaced a 02 in my bronco and I am assuming its the same,
But I have never replaced a knock sensor before, And Its rather pricey so is there a way to be sure its bad? Is it possible it could be reading bad because of the o2?
Old 02-25-2008, 09:26 PM
Ok went to that zone and they said there is no repair guide for this year in both Haynes and Chilton's so no luck there.
No one had a o2 sensor < OEM> but they had a universal 4 wire available by bosh
I got a printout of the code for the Knock sensor
The Pcm has determined that a malfunction exists in the electrical circuit for the knock sensor 1 < bank 1 or single sensor> < bank 1 identifies the cylinders on the opposite bank>
Could this just be a blown fuse?
it also list possible cause of low fuel pressure could the o2 cause that?
come on guys help me out here please
