Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-20-2008, 06:44 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Upcoming weekend project.
I guess 300,000 miles of being rode hard and put away wet finally caught up to my engine. I haven't definitively figured out the cause yet, but cylinder 6 has no compression. I am thinking it's a valve or head gasket. The plug was a little sooty, but no oil on it, so the problem isn't likely to be a broken piston or broken rings. Pulling the valve cover off revealed no broken valve springs or rocker arms. No noise at all. No water in the oil, no oil in the tailpipe. No smoke and the oil pressure is just fine at 45PSI @ 1500 RPM.
To be honest, it hit a high RPM when I was showing it to someone and I think I floated a valve.
Anyways, long story short, I won't touch it tonight because I want to see my Suns with Shaq beat up on the Lakers, but tomorrow night I will likely pull off the passenger head and see if there's damage beyond the head itself. Wish me luck!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-20-2008, 09:23 PM
mike561 mike561 is offline
Re: Upcoming weekend project.
good luck, im STILL waiting to get my car back from the paint shop, im getting pissed too. after that though then engine mods are next starting with a nice new dual exhaust setup, headers and all. cosmeticly, the car is perfect and nothing more needs to be done.
2006 Chevy Cobalt LS
Old 02-20-2008, 09:29 PM
Blue Bowtie's Avatar
Registered Offender
That's pretty sad at only 300,000 miles, but you might have to pull the heads. As you get into the project and have the right rocker cover off, check the valve stem standing height with both rockers backed off. If one isn't at about 1.8" spring height, you may have a stuck/bent valve.
Any numbers from a compression or cylinder leakage test? That might reveal a lot.
Old 02-21-2008, 05:13 PM
94HeavyChevy 94HeavyChevy is offline
to bad my Lakers beat your Suns...but it was a great game
Old 02-21-2008, 07:48 PM
463's Avatar
463 463 is offline
broken toys make sad boys. good luck and watch those shiney white things (your fingers) 463
Old 02-22-2008, 09:40 PM
silicon212's Avatar
Confoundingly Lucid
Yes, it was a great game. We were just plain beat. Outplayed, but we're working a new player into our team so it was just as well. I liked what I saw with Shaq, and once he gets conditioned, watch out!
Anyway, I discovered that I floated a valve, as suspected. #6 exhaust was bent JUST enough to not seal, but the thing that has me stoked is that even after 300k miles, there was no visible wear on the cylinders. The honing crosshatch pattern was intact from the top of the cylinder to the bottom of the stroke, no ridging or tapering evident ANYWHERE on the engine! The piston crown on cyl 2 (the only one that didn't take on coolant when I popped the head) was shiny clean, looked like a new piston. I'm jazzed!
Old 02-22-2008, 11:46 PM
I know this is random but i saw a decal someone had on their silverado's rear window that said "American boys drive american toys" i thought of putting that on mine but i dont wanna decal mine all up. didnt mean to jack your thread silicon lol
Old 02-23-2008, 10:46 AM
463's Avatar
463 463 is offline
good to hear that at 300000 all is well inside the beast. bent valve not to bad. always prep for the worst and expect the best.
Old 02-24-2008, 12:28 AM
silicon212's Avatar
Confoundingly Lucid
Welp, it's put back together again and I am back on the road again.
On the road again! Sing it Willy!
Old 02-24-2008, 09:02 AM
463's Avatar
463 463 is offline
i love happy endings. 463 :chevy:
Old 02-24-2008, 09:49 AM
Registered Offender
What? No carnage photos? Not even one of these?
Reading your news reminds me of tearing down my '94 LT1 at 110K. The worst cylinder had 0.0004 (four tenths, not thousandths) taper and OOR. That's within factory production tolerances for a new engine, not even wear tolerances. And that 110K miles were not kind, gentle miles. It ate three sets of rear tires in that span.
That was just another episode which made me a firm believer in PAO synthetics from end to end.
Old 02-24-2008, 10:31 AM
silicon212's Avatar
Confoundingly Lucid
Your picture looks very, very close. I'll get a picture of it as soon as I can find my power adapter for my camera.
One thing I did while I was in there was used a Dremel on the piston crown to remove the burrs so that I wouldn't have problems down the road with that (increased detonation, a stress point for a crack to form, yadda yadda).
Old 02-24-2008, 01:07 PM
463's Avatar
463 463 is offline
Blue BowtieWhat? No carnage it's all about the carnage carnage carnage right Blue Bowtie.
Old 02-27-2008, 10:46 AM
silicon212's Avatar
Confoundingly Lucid
Sorry about the crappy resolution on my camera (it's a state-of-the-art zero-point-three megapixel LOL), but here you go.
The inset depicts the valve turned 180 degrees to show the bend.
Old 02-28-2008, 11:44 PM
Registered Offender
Meh. Nothing a little JB Weld and a can of SeaFoam couldn't fix.
