Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-20-2008, 05:01 PM
chevymaniactn08 chevymaniactn08 is offline
Starting Problem
My friend is having with this caprice of his.When he turn the key to crank, the starter clicks a couple of times but never touches the flywheel at any point...like the pinion wont comin all the way out to turn the flywheel....if he tries to crank it again the battery starts to get real hot...and this is where we're stuck.
Old 02-20-2008, 06:38 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Starting Problem
There's a short somewhere, likely in the starter itself. Good luck!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-21-2008, 07:43 AM
got the starter checked at autozone and it had no problem kickin on...they said it was good....im gonna check the starter wires out to make sure that its not touching any other wires or a ground somewhere.
Old 02-21-2008, 04:03 PM
j cAT j cAT is offline
does the battery terminal get hot ?????????? if so the terminal that gets hot is in need of cleaning and while your at it remove both +/_ terminals and clean......remove ground first.......install ground last........
