Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 02-20-2008, 12:37 PM
mailee75 mailee75 is offline
Question really need insite...i'm stumped....
Hi all, i'm having troubles with my dakota...it's a 94 sport, 3.9 automatic 2 wheel drive.
so, when i start the truck, it shimmies n shakes, if you give it gas while still in park, it has a high pitched whine that accelerates and goes down with the engine....can't figure it out....when you drive, it seems to be sluggish, like somethings holding it back, transmission seems hit hard and winds out a little when goin into 3rd....transmission fluid is full and doesn't look or smell burnt. we recently put on new brakes, rotors (on front), and rims with wider tires off a durango...but do not have a lift on it yet, so the tires rub a little, but they don't seem to be the problem as this is going on when the truck is in park and you give it gas.....
also, it's not throwing any codes....
how can i tell if i have a vacuum or electronic transmission? also, how can i tell which transmission i have?
any suggestions on what to try or what it could be? thanks in advance
Old 02-27-2008, 09:23 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: really need insite...i'm stumped....
Could be a sign that your coolant and tranny fluid are mixing in the radiator. Look for an oily sheen atop the coolant. Also go beg/borrow/steal a coolant system pressure test kit and test that the system holds the pressure and doesn't drop.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
