Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 02-20-2008, 09:04 AM
bobmack bobmack is offline
Unhappy alternater queston for you
I purchased a 74 beetle, it has a Bosch alternater with a external regulater. there are 4 wires coming out of the regulater (mounted under the back seat, driver's side) The wires are going to the engine compartment. I can understand that the b+ is on the larger post and there is a d+ connecter on th alternater.Here is the sticking point the Bently publications mention a multiple connecter on the alternater. This alternater has no such animal. lt only has two connection points (B+ and D+)where do the other wires go that are just hanging loose.What and how many wires are connected on the alternater with an internal REGULATER?
if anyone out there can shed a light on this, please do.
Thanx in advance----bobmack
Old 02-20-2008, 02:16 PM
bugman742002 bugman742002 is offline
Re: alternater queston for you
what does your alernator look like? does it have a large diameter end or is it the same diameter at both ends? if it is the same it has a generator. also check out this fourm. they can help you out. www.shoptalkfourms.com
Old 02-21-2008, 09:12 AM
Thanx for your answer bugman. It is definately an alternator(bosch). It has a larger post that holds the B+ wire with a small nut, the D+ wire is smaller and connects via a female connector that just pushes on.The regulator is made by motorola and has a red, green, brown, and blue wire coming out of it.These wires are designated d+, df, d- and no designation on the 4th.These wires are short, going into a connecter that in turn that goes to the engine compartment.As I stated in my earlier post, the D+ goes to the smaller spade connector on the alternator along with a larger wire from the Batt that goes to the B+ post.It's the two wires (DF and D-) that are just hanging there that has me stuck.
Old 02-21-2008, 06:42 PM
that sounds like the internaly regulated alternator. go to the web site i mentioned earlier ask someone there or do a search i'm sure someone there has a wiring diagram for your set up. they deal with aircooled vw's only and we have qutie a few members there that can assist you better than i can.
Old 02-23-2008, 06:30 PM
BoatCop's Avatar
BoatCop BoatCop is offline
You can check Speedy Jim's Web Page. He's an absolute genius when it comes the VW electrics.
http://www.netlink.net/mp/volks/htm/elec.htm
Scroll down to the Alternators/Generators section.
Alan
BoatCop
