Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 02-19-2008, 09:20 PM
solsurf solsurf is offline
Rack and Pinion 91 Celica
I got a lot of play in my steering, almost 6inches. Kinda scary while driving. Someone told me it might be the R&P. Anyone got pointers or pics of swapping it out? I bought a Chiltons online, but it's been almost 2wks and still no book. Any help is greatly appreciated.
Old 02-19-2008, 10:24 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Rack and Pinion 91 Celica
Welcome to the AF!
See where the free-play comes in by having someone turn the wheel back and forth a couple of inches and see where the steering gear stops moving. It might be in your steering gear joints, the suspension arm ball joints, the rack, or the front wheel bearings.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-19-2008, 10:43 PM
yeah my steering wheel isn't centered. it doesn't pull either way too. i have to turn it almost 3 inches either way before the car catches. dunno if that makes sense. Thanks.
Old 02-20-2008, 03:23 PM
Brian R.'s Avatar
Resident Chemist
Yes, it makes sense. Just find out where the play is and replace it. Probably just one component is bad.
Old 02-20-2008, 11:11 PM
Thanks for the reply. I have another issue, i believe a vacuum hose is missing. Any ideas as to where this is suppose to be connected? It is sucking in air. Could be the culprit to my 19mpg stat. Thanks again.
Old 02-21-2008, 11:45 AM
Brian R.'s Avatar
Resident Chemist
You should have a vacuum hose routing diagram stuck on the underside of your hood. If not, get one free from a Toyota dealer parts counter. They will special order yours if you give them your VIN. If you don't have one, get the emissions/tune up specification sticker also.
BTW, it looks like you have an open port on your intake. Plug it.
Old 02-22-2008, 11:52 AM
k1ngsky k1ngsky is offline
you dont have to plug the side hole on your intake, just add in a small filter.
Old 02-23-2008, 01:01 AM
No diagram under my hood. Still waiting for my Chilton's manual to come in.
But I'm talking about the thing circled in red. Thanks.
Old 02-25-2008, 12:17 AM
Brian R.'s Avatar
Resident Chemist
Plug what ever it sucking air and order a vacuum hose routing sticker so you can accurately route its hose.
