high idle
i just got done putting my vr4 motor in.i started it up,everything was fine byside my idle.the idle sits at 2000rpm and wont go down..im not to sure wats going on..everything is hook up and plug up..any ideas in mind???
Re: high idle
vacuum leak.. or maybe you need a new IAC.. Just a guess..\
Jason |
Re: high idle
- Pressure test for vacuum/boost leaks.
- Make sure the BISS is in the TB and properly adjusted. - Make sure the throttle cable isn't tightened down where it's holding the throttle open a little. - I haven't seen an IAC hold the throttle open, usually does the opposite and causes a stall condition, but I guess its possible.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
