Old 02-24-2003, 06:41 PM
slim.AP1's Avatar
slim.AP1 slim.AP1 is offline
s2000 Update
I sprayed my s2k.... turned out really bad... but it's to be expected as my first time spraying a model. I kept getting these bubbles and such.. so annoying...
Old 02-24-2003, 06:44 PM
clatescivicr clatescivicr is offline
Its hard to tell from the pics, but I defin't so see anything a rubbing compound can't take out. Car looks fine to me, just rub it out in about a week.
Clate - I'm back
Old 02-24-2003, 08:28 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
did u use primer??
remeber... light spray and wait like 5 mins between thin layers of coat...
dun worry u would learn from ure mistake just like me....
imagine two spray cans on one kit..... so think u cant see the panel lines anymore
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 02-24-2003, 08:50 PM
ultraxduce ultraxduce is offline
Send a message via AIM to ultraxduce
it looks to me like dust got caught in the paint...
i agree with clatescivicr about the rubbing compound. should be no problem for it. maybe use a high grit sand paper like 1500 or 2000 to get the rough spots out. then go at it with the compound, then some nice wax
good luck.. looks good so far...hehe. nice idea for a stand... might use it next time
Old 02-24-2003, 08:55 PM
slim.AP1's Avatar
Originally posted by endlesskev86
did u use primer??
Nope, no primer
lots of dust.. but ah well.. i'll try the sanding technique and re-spray it
Old 02-24-2003, 09:42 PM
thats what happend to my first two kits...
no primer...
Old 02-24-2003, 10:34 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
I spray outside, and just before spraying, I wipe down the body with a swiffer cloth, just to make sure it's clean.
Old 02-24-2003, 10:35 PM
integra818's Avatar
By the way, what kind of paint are you using? did you heat the can? what temperature were you spraying at?
Old 02-25-2003, 12:25 AM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
Cant tell in the Pics of the bubble you speak of but this may have been caused because of 1) No Base Coat of Primer 2) Irregular Temp. 3) Oily Surface......Yet the Pics make the piece look very nice....good job...
Old 02-25-2003, 12:41 AM
chaos's Avatar
chaos chaos is offline
AF Premium User
no primer...
Exactly the same thing happened with my 1st kits as well. Luckily I discovered AF pretty soon after!!!
Old 02-25-2003, 01:08 AM
primera man's Avatar
"P-Man"
Sand it back and prime the body before painting.
Have a read of this to help you out.
Most bubbles are caused by paint going on to thick.
View All My Models Here.
Old 02-25-2003, 01:12 AM
ales's Avatar
ales ales is offline
Forza Schumacher
too thick, and also spraying from too close a distance.
