Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-19-2008, 02:52 PM
ecamc ecamc is offline
Send a message via AIM to ecamc
Cool Weird electrical issues
My son's 1999 Neon will intermittently just not want to start. The weird thing is that you put the key in and it acts like the battery is totally dead. No dash lights, dome lights, etc. You take the key out, reinsert and try again, sometimes it works, sometimes it takes two or three tries. When it 'works', you get all of the dash lights, and the engine fires right up.
Doesn't make sense. If the battery was drained, it wouldn't work later, and when it works there is no apparent draining of the battery, either.
Any thoughts?
Old 02-20-2008, 07:24 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Weird electrical issues
Might be a bad ignition.
2003 Dodge SRT-4
Old 07-26-2009, 10:13 PM
butman_33 butman_33 is offline
I had a similar problem...my 96 neon wouldn't start and the interior lights, radio, dome light etc. would sometimes work and other times nothing at all. What caught my attention was a clicking sound when I turned the key to the off position...I changed the ACC relay and everything worked just fine.
Old 07-26-2009, 10:15 PM
Maybe even check the connection on the battery terminals...might be loose.
Old 07-26-2009, 11:24 PM
racerxpl racerxpl is offline
Neons are noted for wiring melting under the relay box. I have had two do it and have seen a lot of posts on the net. Some of the symptoms can be so very weird. Like the wipers turning on for a second.
Old 08-05-2009, 09:59 AM
HPNOTIQracing HPNOTIQracing is offline
sounds like ignition or at least the wiring to it. or it could be a loose wire in you charging system. bat to ground, batt to starter, batt to relay box., ect
