Old 02-19-2008, 01:26 PM
jar92380 jar92380 is offline
Driver Side Trim Piece
Hello
I just noticed that my switch panel trim, the actual section that holds the electric mirror controller is actually broken. Anyone know where I can get a replacement for just that gray piece?
Thanks
James
Old 02-19-2008, 03:57 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Driver Side Trim Piece
the year make model would help here Yo !
1999 Grand Am SS 3.4 OHV
Old 02-19-2008, 04:13 PM
sorry about that. Its a 2005, Grand Am SE V6
Old 02-19-2008, 04:46 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Either a dealer or salvage yard. Could also try e-bay. If it's the same as a '98, I'll sell ya mine
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-19-2008, 05:54 PM
You wont find many 2005's in the salvage yards,
but any 1999-2005 should be the same.
You can buy after market pieces I saw somewhere that are painted around the edges.... I look and see if I can find those for you.
Old 02-20-2008, 08:00 AM
xeroinfinity thanks for looking, please let me know what you find.
Old 02-20-2008, 05:18 PM
found it !
http://www.customgrandam.com/index.htm
They have all sorts of cool stuff.
Old 02-22-2008, 09:27 AM
unfortunately they don't have the piece that i am looking for. Remember its the piece that holds in the electric mirror controller on the driver side, hell i'll even buy the wholetrim piece if i need to
Old 02-23-2008, 12:53 PM
I'd go to a salvage yard and find a used one, shouldnt be much more then $10.
1999 and up will work, it would need to be the same sedan or coupe. That little piece is a PITA to remove too.
Old 02-23-2008, 02:34 PM
actually i went to a local stealership and they had one in stock for 9 dollars and they even installed it for free. Thanks a bunch for all the replays guys
