Old 02-19-2008, 11:40 AM
ScaleTuned's Avatar
ScaleTuned ScaleTuned is offline
Scratchbuilding pulleys?
Anyone like to share their idea's or methods for making engine pulley's? Doesn't matter if styrene or aluminum, just looking for different ways for a project I'm working on. Thanks! ~ Mike
Old 02-19-2008, 01:33 PM
Madish's Avatar
Madish Madish is offline
Re: Scratchbuilding pulleys?
Well, I modify them with masking tape, painted black.
It's a method based on this tutorial
http://www.italianhorses.net/Tutoria...elt/dbelts.htm
Old 02-19-2008, 03:12 PM
ScaleTuned's Avatar
I was talking more about the pulley's themselves, not the belt. But nice tut. in that link anyways.
Anyone?
Old 02-19-2008, 06:18 PM
CFarias's Avatar
CFarias CFarias is offline
Check with Scale Auto magazine or Ebay for the "Car Modeler 2001" magazine. This is/was an annual publication that featured the machine work of Augie Hiscano. He deals in detail with how to machine pulleys. This is a must have magazine for those wanting to machine their own parts.
If you don't have machine tools handy you could try resin casting a set from a good kit.
Old 02-19-2008, 06:34 PM
Enzoenvy1's Avatar
I have layered styrene with a mount for a dremel and used an xacto blade to make true and accurate round parts. Since I have no machine shop or lathe it was all I could do. Simple cutting can provide great results and detail. BUt this is me, and I am sure there are better options.
Old 02-19-2008, 11:24 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
If you have access to a Waldron hole punch, something like that would work great for making pulleys from sheet styrene. Just sandwich together different diameter pieces, and voila, one pulley.
Old 02-20-2008, 08:51 AM
ScaleTuned's Avatar
thanks for the tips. I'm experimenting now using thin slices of aluminum tubing I cut with a mini miter saw. I think I will try using styrene chucked in the dremel also. I will post the results. I wish I had a lathe, but not really in the budget right now.
Old 02-20-2008, 10:23 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Yeah, but how many people do you know actually have one of these mythical contraptions?
Here's another idea I used in my pre-lathe days:
Get several diameters of brass tubing. Cut a 3ish inch length of each, and sharpen one end of each (use a file or the like to 'cone' one cut end). Place the sharpened end on a piece of sheet styrene on a sturdy wooden surface, and hit the other end of the tubing several times with a mallet. There- a low rent set of punches that will cut small discs of styrene. Sandwich these discs together to make pulleys.
Obviously you'll need to resharpen the cutting edge often (brass is pretty soft and the edge isn't very durable), but it will do the trick.
PHOTOBUCKET SUCKS
Old 02-21-2008, 07:54 AM
ScaleTuned's Avatar
Thanks MPWR for the tip. I was looking at the punches that Micromark sells but their $40.00. I may go to hobbylobby at lunch to see about those mythical hole punches also!
I did have some luck with layering thin slices of aluminum tubing, looks nearly like a machined piece. Adding some PE pulley faces and they look outstanding. I'll try to get some pics up later tonight. A lathe is looking more and more attractive...
Old 02-21-2008, 11:40 AM
AFAIK you wont find the hole punches at HL. Ive never seen one there. If I had, I'd probalby have jumped on it pretty fast.
And I actually know quite a few people who have the Waldron punches, but most of them are into aircraft & armor modeling, where their use is more common.
Old 02-21-2008, 01:57 PM
ScaleTuned's Avatar
Hobbylobby did have the hole punch, I seen it there before. Picked it up at lunch. Not sure what the punch your talking about looks like, but this one has a wheel on it with various sizes of holes you can punch out. It was 7.00. Says right on the package you can use it for plastic, etc. I'm going to give it a go later tonight.
Old 02-21-2008, 09:11 PM
MPWR's Avatar
Turns out I have one also. It's a very nice tool, but it's rather expensive and not the most obvious or necessary modeling tool on my workbench. They've gotten more expensive since I got mine, and a good bit harder to find- rumor has it that they're no longer being made. You might be able to get one here. It would be perfectly good for making pulleys, provided that you don't need one as large as 4" in 1/24.
PHOTOBUCKET SUCKS
Old 02-21-2008, 09:53 PM
Yea, they arent the cheapest tool in the world, but I woudlnt mind having one evnetually.
Im concidering making one in the machining classes that Im taking at the local comm. college.
Old 02-22-2008, 08:24 AM
jmesawitz's Avatar
jmesawitz jmesawitz is offline
I was looking at a similar punch set from Miro-Mark
MICRO PUNCH SET
Item Number: 83513
$40 is a bit much but less than the other.
Old 02-22-2008, 08:34 AM
ScaleTuned's Avatar
sorry mates, fell asleep last night ... ha ha ha
I will post pics later. The rotary punch tool I got from HL works very good actually. I may pick up the punch from MicroMark though because it offers larger sizes than the rotary tool.
