Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-19-2008, 10:48 AM
Ericnic Ericnic is offline
99 Suburban won't shift from Park
Last night, I replaced the vacuum booster on the brakes. Now it will not shift out of Park while it is running. You can turn the key one click past off, shift to nuetral, then start it. Also the cruise control has stopped working. Could the relay/switch that sits on top of the conection going to the brake pedal be bad?
Old 02-19-2008, 11:16 AM
j cAT j cAT is offline
Re: 99 Suburban won't shift from Park
when you messed with the booster install wires/connectors at base of steering collum/brake pedal must be damaged or disconnected...
Old 05-14-2008, 05:43 PM
fierodough fierodough is offline
I have the exact same problem! and oddly enough, I also changed the brake booster... What wire was damaged?
thank you!
Old 05-15-2008, 08:42 AM
The final outcome was I replaced the brake relay switch and the retaining clip. I think when I pulled the retaining clip off, that I damaged it enough that it was not holding the relay switch in the right position. If I remember right the switch was aroud 10 bucks, and the clip was about a buck.
Old 05-15-2008, 08:55 AM
thats what i figured...not an easy place to work....thanks for the feedback.....
