Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-18-2008, 11:24 PM
c15002wd c15002wd is offline
97 suburban turns over but wont start
i have a 1997 chevy suburban c/1500 2wd thats a daily driver. try to start but all it does is turn over checked fuel pump it turns on checked for spark ok there too, air the same ,so i put a gauge on it try cranking,got a reading of flickering btween 40 & 55 at the fuel rail. looked into the TB to see if i see the injectors doing something, to no avail. anybody with any suggustion feel free no matter how simple. thanks in advance.
Old 02-19-2008, 08:28 AM
Old Dave Old Dave is offline
Re: 97 suburban turns over but wont start
You need a minimum of 55-61 lbs. of fuel pressure at the test port on the fuel rail 2 sec. after you turn the key to "ON" ...NOT START. The pump should come on and run for 2 sec. and then shut down after it pumps up to pressure. These Vortec's are very picky about the minimum fuel pressure and sometimes won't start if it's even 1 Lb. too low. I fought my 97 Suburban for about 6 mo. with long starts (5-8 min.) and my pressure was 54 Lbs. key on not running. Replaced the pump about 18 mo. ago and it's been fine since. You might try replacing the in-line fuel filter first since it's much easier and cheaper than the pump. It's located along the frame rail just behind the driver's seat. I would only use the WIX brand and they have an arrow on them indicating which way they go on. FYI, mine had 118K on the OEM pump. Good luck.
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
Old 02-20-2008, 04:02 PM
thanks old dave that was just what i needed to know.went today bought fuel filter & pump.changed the filter first no start changed the fuel pump started right up. found the ground connector inside the tank black like if it was burnt or something and the ground to body xtra rusty. made sure the ground in the harness coming from tank wasnt rusty and made sure that current went through it before putting back together.made new ground on frame with no rust and sprayed undercoeting on top to prevent future rust. now my burb is back on the road thanks
Old 02-20-2008, 04:07 PM
just for know millage 138547
Old 02-21-2008, 07:29 AM
Glad you found the problem and hope your tank wasn't full...
Wife is a late 1951
Old 02-21-2008, 03:23 PM
j cAT j cAT is offline
body ground for fuel pump at frame rail a common cause of fuel supply issues.. you stated the the pressure was jumping from 40-50 psi,,,what was the pressure after pump change out?
Old 02-21-2008, 11:26 PM
with the key on it went up to 61,after i turned on it went to 55
Old 12-20-2011, 01:05 PM
rtoney rtoney is offline
How or where do I find the ground wire?
Old 12-20-2011, 01:58 PM
welcome to the forum .. If you have a problem start a your own new posting , give your vehicle details. also what was done or tested. with no start check fuel pressure. your vehicle should be 60-66psi key on engine off. use a pressure guage.
Old 12-20-2011, 02:14 PM
Thanks for your response but I am not sure how it answered my simple question.
If someone else could give the answer that would be great.
Old 12-20-2011, 04:31 PM
If you do not understand what I stated in the prior post you should have the vehicle towed to a repair shop for diagnoosis.
also get a repair manual for your vehicle then post back with what testing you did and what the fuel pressure is. also any DTC failure codes pulled.
once again you are responding to another members vehicle issues. make a new post with your issues and give vehicle details.
Old 12-20-2011, 04:55 PM
J CAT
If you do not want to answer the question then stay out of it, maybe there is someone else that might.
It's not that hard to figure out, if you are not answering the question then I don't need to hear form you.
Thank you once again for responding but I do not need another from you.
Rick
Old 12-20-2011, 05:10 PM
777stickman 777stickman is offline
On my '98 Sub the ground is on a support rail just forward of the tank. Close to center or maybe a bit to the drivers side.
Don't get pissed over the previous responses. It's really one of the hopefull rules of the forum to start you own thread. That way you can give us all the particular issues you're having.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-20-2011, 07:19 PM
SuperDanny SuperDanny is offline
J CAT
Rick
Dude,
JCat is one of the most helpful members here on the forum. He was not being a smarta$$, trust me. He was simply stating that if the previous post didn't understand the answer he gave, it would be time better spent taking to a mechanic. Sometimes I need to be told that too. Saying someone should invest in a factory service manual is also an excellent piece of advice. I have a shop manual for every car/truck I own.
'95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, CIA TriY headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
74 Ford F100, 390 auto, longbed
98 Suburban LS 5.7L Vortec, stock
08 C1500 Suburban, 2WD
Old 12-21-2011, 08:51 AM
777 Stickman,
Thank you for your response to my question I will give it a look. I was not as upset as it may have appeared but all I was looking for was a simple answer to a simple question. I was not looking for someone to make an attempt at diagnosing a problem therefore a long explanation of what I have or have not done was not in order.
I am a part of other forums and am familiar with duplicate questions and jumping in on a thread.
The fuel pump ground was mentioned and my question was not out of place for this thread.
Now, if this does not take care of my issue I may start another thread but we will see.
Thank you for your answer once again, I think any other discussion on this question would be a moot point.
BTY
My name is Rick not Dude as per a previous entry
Have a good day
