Old 02-18-2008, 11:23 PM
sumi123 sumi123 is offline
'92 Lumina Heater Controls
My Lumina has push button controls for the heater and A/C . No matter which button I push the unit essentially stays on Defrost. Can't get anything to blow out of the side vents or floor vents. Fan works fine just can't select which vents the heat is to come out of. The air blowing on the window doesn't seem to be as hot as it should be. There is a slide bar that you move left or right to switch from cool to heat setting. The little lights work indicating which button has been pushed.
I saw in another thread that there might be a vacuum leak but I'm not sure if that applies to this unit. It seems to be a total electronic unit but I'm not sure.
Thanks for your help in advance.
Old 02-19-2008, 12:00 PM
cadgear's Avatar
cadgear cadgear is offline
Re: '92 Lumina Heater Controls
Sounds like vacuum to me. These controls are electro-pneumatic, when you push a button to select it electronically activates a solenoid which in turn routes vacuum to the airgate next to the heater core. I'm willing to bet that you have either a vacuum leak somewhere along the way or a plugged vacuum line somehow. When there is no vacuum going to the control unit, it defaults to the defrost air pathway.
Old 02-20-2008, 02:52 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Check fuse & courtesy panel also. Fuse panel in glove box, courtesy panel under right side of dash.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 02-21-2008, 10:31 AM
Thanks guys!
I'm starting now with the fuses and then if no luck there I'll work my way through the vac system.
I appreciate your quick responses.
Thanks Again!
Old 02-21-2008, 12:05 PM
brcidd's Avatar
brcidd brcidd is offline
It's a vacuum leak- look underhood at where vacuum line crosses over top of serpentine belt at power steering pulley- they are usually just unplugged here by someone who bumped it- or forgot to plug it back together- or it can be worn through by rubbing in the pulley- even through the black plastic conduit....takes about 30 seconds to fix usually- just splice a piece of rubber hose over the broken vacuum line- you can cut off spare rubber hose from the windshield washer hose if you need it-- I have done several this way in the parking lot where I work.......
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-21-2008, 06:43 PM
j cAT j cAT is offline
well if your not sure i guess it's about time to find out ......if you don't want to get dirty best let a professional handle it.........
Old 03-02-2008, 06:45 PM
Thanks everyone for your advice. I traced the problem to a broken vac. tube located under the battery. After a quick fix as suggested by brcidd it is now back up and running better then it has for a few years. Thanks again everyone!
