Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 02-18-2008, 07:14 PM
roku roku is offline
Angry HELP! TS won't fire up
My 93 Trans Sport won't fire up.
I,ve had this problem for 2 months now and I'm about to burn the damn thing. It cranks fine, but won't fire up. Crankshaft position sensor and the camshaft pos. sensor have been replaced and nothing still happens.
There is a spark and fuel pressure on the pipe, but I think there is no fuel in injectors.??
Help me, plz!
Old 02-19-2008, 07:28 AM
LMP's Avatar
LMP LMP is offline
Re: HELP! TS won't fire up
What you describe is exactly what I experienced nearly 2 years ago with the exact same car. (a 3.8 from what you say).
http://www.automotiveforums.com/vbul...d.php?t=558604
PRoblem is the ignitionmodule, this wafer like component under the coils.
$70 new on e-bay. Yes, you have spark..but signal to trig the injectors is separate from the one that trigs the spark ; it comes also from the cranshaft sensor and is amplified through the ignition module then fed to the computer. THe amplifier section is dead. Change the ignition module.
here is one : http://cgi.ebay.com/ebaymotors/ws/eB...3D9%26_fvi%3D1
THis is the exact model #D1977 and he ships worldwide (says $20 shipping for TUrkey..so I figure something similar to Finland)
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 02-19-2008, 08:53 AM
LMP's Avatar
LMP LMP is offline
I think you won the bid on e-bay as Hatomni
Old 05-29-2008, 06:01 PM
Yes I bought the module via ebay. Thanks for the hint. It didn't help though.
Now the car is running fine after tearing half the car apart. The problem was a low voltage wire between the fuse box and the computer. It had a " cold soldering" and voltage reached the computer, but no amps.
Today my TS did it again. I checked the codes and got 18! I didn't find code 18 from any diagram. Anyway I removed the IC module and brushed the mounting plate shining clean and it runs again.
Still I wonder this weird code 18... what does it mean?
Old 05-30-2008, 04:18 PM
vesamaan vesamaan is offline
Moi
Mun -94 manuaali kertoo koodin 18 vastaavan uutta P0341 koodia: Cam/Crank Error
Same in english: In my -94 manual chart says code P0341 was former DTC 18: cam/crank error
