Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-18-2008, 04:23 PM
mayford5 mayford5 is offline
96 JGC Guages stop working but still power
Have a 1996 JGC that every once in a while the guages all drop to zero and the information center blanks. I still have power and can drive it. To solve this I have to pull over and restart the vehicle. Anyone have an idea what this could be?
Thank you
Old 02-19-2008, 08:09 AM
Bob D. Bob D. is offline
Re: 96 JGC Guages stop working but still power
Try cleaning the battery terminals.
Old 02-19-2008, 11:43 PM
tried that even replaced a battery cable. Still having issues. We thought it could be the alternator because for some reason someone had put on a 90 instead of a 120 so we swapped that out also. Just strange. Is it possible one of the computers is going out?
Old 02-27-2008, 09:32 AM
Has anyone else ever had or worked with this problem before?
Old 02-28-2008, 07:19 AM
reekor reekor is offline
I have the same issue right now with a 96 also, it too cold out to deal with it right now. My guess is a Battery Temperature Sensor or poor connection at the computer.
Thank you
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 03-18-2008, 07:28 PM
lojbeck lojbeck is offline
My 1996JGC had the same problem. There is an electrical connector in the wiring harness just to the left of the glove compartment with aprox. 6 wires, rectangular in shape. This is inside the cab and and be reached without removing any trim. On my Jeep, there was a bad connection at this plug. This caused the wires to heat up, resulting in an bad connection. I simply cut out the connector and installed butt-splices on the wires. BTW, it took me a year to find the solution to this problem. Hope this helps.
