Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-18-2008, 05:17 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Coolant leak?
I have had the lines preassure tested, I have checked all the lines and connections, and i replaced all the hose clamps with new ones, but my reservior fluid level still keeps dropping. Its a slow leak, but i cant find it... Do you think the engine is burning coolant or is there someting else i should check? Thanks
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 02-18-2008, 05:26 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Coolant leak?
Does the car smoke any? Does it look like there is water in the oil? Does the level in the resevoir get lower or does it get completely dry?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-18-2008, 09:07 PM
Re: Coolant leak?
I dont think the reservior has ever been empty, it just gets really low, but it might ill have to let it go and see... But no, it has never shown any signs of burning coolant engine wise, and thats the part I dont understand... Where is it going? I just changed my oil yesturday and there was no sign of water.
Under The Hood:
Interior:
Old 02-18-2008, 09:34 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Coolant leak?
As the car gets up to temp the level of coolant in the resevoir will get lower but once the car cools down it's suppose to rise back up. My gut is telling me that I've got this backwards, am I correct.
Old 02-18-2008, 09:54 PM
Holset powered 420a
Re: Coolant leak?
I believe your right ned.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-18-2008, 10:20 PM
Re: Coolant leak?
You are correct, but even the cold level still drops over the days...
Under The Hood:
Interior:
Old 02-18-2008, 10:30 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Coolant leak?
How's your gauge looking?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-18-2008, 11:35 PM
Re: Coolant leak?
Guage reads normal... I was wondering could it be a return line from the reservior, or to it? Would that be included in a preassure test?
Under The Hood:
Interior:
Old 02-19-2008, 08:19 AM
ned032002's Avatar
Re: Coolant leak?
I've always wondered if you don't have a very good seal on your resevoir then the coolant could slowly evaporate, is this true?
Old 02-19-2008, 08:22 AM
Holset powered 420a
Re: Coolant leak?
There is a drain coming from the coolant top anyways, the tank isin't suppose to be sealed shut.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-19-2008, 06:18 PM
JoeShmoe's Avatar
Re: Coolant leak?
Yeah, you don't want any boiling liquid trapped inside a plastic tank to explode.
Old 02-19-2008, 11:03 PM
ned032002's Avatar
Re: Coolant leak?
So do you think that the fluid will evaporate?
Old 02-20-2008, 09:15 AM
JoeShmoe's Avatar
Re: Coolant leak?
Without proper seals running to the engine, it depends on where the fluid lands.
Old 02-20-2008, 04:36 PM
Re: Coolant leak?
So does anyone have any ideas or thoughts about what could be wrong? I know i dont really have any signs for you to use to diagnose something, the only thing i have to add is that my reservior ran out today...
Under The Hood:
Interior:
Old 02-20-2008, 04:46 PM
JoeShmoe's Avatar
Re: Coolant leak?
Is your sending unit good? I would just replace since its only a couple of bucks.
***EDIT***
And also the thermostat while you're at it.
