Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 02-18-2008, 09:39 AM
onyx2002 onyx2002 is offline
First time engine light on 90 dx hatch
Guys,
I bought my 90 dx from the original owner, a 72 yr. old lady that only had 105,00km on this thing when i got it...she had all service work records etc...
anyway,, before i make anyone slobber and droole,,,, it is a canadian car, and sat outside all the time, so i had to do major body work repairs from salt damage.
But my problem is i don't know much about these cars, and I plan on keeping this car as my daily driver. I noticed yesterday for the first time in the 6 months i've had it, the engine light came on.. It reset itself when i turned the car off,, can i get an error code from the ecu ??? i beleive these are obd0 ?? so no scan tool option,,, is there a ecu code list somewhere here?? and how do i get the codes?? is it engine light flashes( mine didn't show any) or is there somewhere else i need to look, and how long do the codes stay on the ECU??
Old 02-18-2008, 01:21 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: First time engine light on 90 dx hatch
The code will be stored in the ECU, there will be a light on the cover of the ECU itself and that is where you get the flashes that OBD1 cars get through there CEL.
Here is a list of codes taken off another Forum:
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Old 02-18-2008, 09:06 PM
Thnx a ton GreenBlurr,,,
now how the heck do i determine what code i have?? and does this ecu store more than one code,,, can i go through the history to look at any previous codes??
Old 02-19-2008, 07:12 AM
Kind of a Big Deal
Yes, if a code is stored it will playback all codes it has. 1 short flash = 1 and 1 long flash = 10.... so if there is 2 long flashes and one short flash thats a code 21. then it will pause between codes and show the second one (if there are any). then will repeat as many times as you want automatically (it will just replay the codes)
