Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-18-2008, 01:14 AM
00rodeodave 00rodeodave is offline
Exclamation tranny question?
I have a 2000 rodeo ls v6. The motor is new (long horrable story) but the tranny has 80k. I tow a tent trailor that weighs in at 2k. It tows fine plenty of power ect. After about 100 miles the tranny starts to shift oddly and get hot. The warning light never comes on but it tries to stay in over drive.
I thought towing in 3rd would help but no luck. I had a flush and filter change and added an external cooler but it still has trouble. The only difference from stock is the tires. the stock ones were 29" od the new ones are 31" od. But it had issuse with the smaller tires and towing to. Any help would be a blessing. The manual says it can tow 4500 lbs. I am at the end of my rope
Dave
2000 rodeo ls ,3 ind. off road lift, 31" geo-landers
rancho 9000/s
72' 1200 hd custom (money pit!)
03' suzuki aerio sx
07' suzuki sx4 awd ( best bang for the buck )
Old 02-18-2008, 08:08 AM
Ramblin Fever Ramblin Fever is offline
Re: tranny question?
What's the maintenance history on this tranny?
I know you just recently had the fluid/filter changed, but had you ever changed it before that, and how often??
Is this all *new* since the install of the new engine? Or has it been ongoing for a while?
The difference in tires shouldn't have anything to do with it; my truck came stock with 29" tires, I've been running 32" tires for over 4yrs, and I've pulled a load twice as heavy as yours for over 60% of my trucks 183k mile life with the automatic being original.
I'm wondering, if this all started after the new engine, if they lost some ATF fluid at the time of the swap and didn't refill it, this will burn that tranny in quick order. Or, if the ATF fluid was left in the tranny too long; i.e. these tranny's need partial ATF fluid swaps every 15k miles, or tranny flushes every 25k-30k at most....but I would NEVER flush an auto tranny again, period.
Also, was your coolant system flushed at the time of the new engine, i..e what condition is your radiator in?? Also, next time you drive the truck, take a look at your volt gauge, if it's down near 12V's, let me know.
Keep us posted.....
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 02-18-2008, 03:59 PM
FL 3.2L FL 3.2L is offline
This is what I'm wondering. Where is the coolant temp when all of this is going on? I'm wondering if the rad has enough deposits to compromise the tranny fluid cooling.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 02-18-2008, 05:47 PM
IT HAD 50 K ON IT WHEN I GOT IT. I DID A FLUSH FILL AT 51K. IT LOST A HEAD GASKET AT 56K. GOT IT FIXED AND DID A PARTIAL ON THE TRANNY. THEN IF THAT WAS NOT ENOUGH IT DROPPED A SLEAVE AT 69K.
SINCE I HAVE OWNED IT IT HAS NEVER WENT OVER 3/8 HOT EVEN IN 105 TEMPS. THE RADIATOR WAS REPLACED TWO DAYS AFTER I GOT IT. BUT I DID NOT TOW ANYTHING WITH THE OLD MOTOR.THIS ONE HAS NO VOLTAGE GAUGE.
Dave
rancho 9000/s
03' suzuki aerio sx
Old 02-18-2008, 05:52 PM
Sounds like the rad is ok...
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 02-18-2008, 07:32 PM
What about the thermostat, has it been replaced AND is it an OEM Isuzu one?
The aftermarket thermostat's do not keep these engines cool enough...have you checked your antifreeze level?
1997 3.2L V6 Rodeo
Old 02-21-2008, 12:40 AM
factory replaced thermostat
Dave
rancho 9000/s
03' suzuki aerio sx
Old 02-21-2008, 07:24 AM
Try double checking the ATF level too see if it's low, by chance.
1997 3.2L V6 Rodeo
Old 02-21-2008, 08:23 PM
I Checked The Levels Everthing Is Good.thanks For The Info. Its Going To Have To Get A Check Up. I Am Going To Take It To A Shop $
Dave
rancho 9000/s
03' suzuki aerio sx
Old 02-21-2008, 10:13 PM
Let us know what the outcome is??
1997 3.2L V6 Rodeo
