Old 02-17-2008, 05:30 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
I think I blew a rod or something
(1998 GMC 2500, 5.7L, 4x4)I have a major problem. I was towing a trailer up a big hill. The engine kicked down a gear and hit 3000 rpms. Kept going it kicked down again and hit 4000 rpms. Before i let off the gas because i didnt want to blow it up, the engine started knocking/Tapping very load. It sounded like a machine gun going off under the hood. I was thinking i blew a rod, but the truck still ran. I lost a lot of power and it feels like im running on 7 cyl. The noise went away, but the truck sounds like it wants to stall at low idel and shakes bad. Starting off, not much power, sounds and feels like maybe a mount broke. At higher speeds, its fine. Starts up everytime, no oil leaks. What happened? I was told maybe it was a lifter and it offest a rod. Im in the middle of changing the plugs and wires. I have one more to do in the morning. The old plugs had little wear on them and looked good. Any help would be great.
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 02-17-2008, 07:18 PM
777stickman 777stickman is offline
Re: I think I blew a rod or something
1. Pull plugs back out and do a compression test.
2. Pull valve covers and compare rocker movement at each cylinder.
This is just a start to find what cylinder is the problem. Could have broken something in the valve train, maybe a valve spring, that allowed a valve to hit the top of a piston?? And the list just goes on from there.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
