Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Tech Articles and Writeups
Old 02-17-2008, 11:29 AM
rs97eclipse1695's Avatar
rs97eclipse1695 rs97eclipse1695 is offline
Send a message via AIM to rs97eclipse1695
HID Write-up (Projectors)
Install Time: Roughly an hour depending on your experience.
Tools needed: Wire cutters, strippers, and crimpers. Electrical tape if you feel the need.
AF Discussion of HIDs and good HID info can be found HERE.
Kit
It's a really simple install.
Start off by removing the bulbs that are in your lights now and replace with the H.I.D. bulbs. There are 3 wires coming from the factory harness. Don't disconnect the wiring harness, otherwise you'll have to cut the harness off. From the harness there are 3 wires, a ground and 2 power wires (one for high and one for low beam). Green and black are the 2 you need. (positive and negative obviously). Connect those 2 to the 2 wires going into the HID box. Mine were logically backwards. Green went to black and black went to red. Strip and wire it, but don't crimp them yet. Instead, plug your bulbs into the box, connect all the plugs (color coordinated) and flip on your lights.
If the H.I.D. you just hooked up:
Does Not Come On - Go back to your wires you didn't crimp, flip the connections, and test again. The H.I.D. should come on at this point. If it doesn't, check your connections.
Comes On - turn your lights back off, crimp your wires, mount the box (keep vibrations to a minimum), and tuck your wires away from anything moving (i.e. pulleys). Next, repeat the above with your other light (you can skip not crimping the wires and testing because it will wire the same way as the first one you wired.)
Any questions, just ask.
Halogens
HIDs
Here are a few pics I managed to snap.
Just sex...
Driver Side Ballast Behind Computer
Passenger Side Ballast Crammed In The Small Ass Hole (only place I could find to stick it...ideas?)
Mounting the Bulb
Rubber Cover
Brightness...
Yes I'm aware my lenses are scratched all to hell. Looking for a clear "tear off" if you will to put over them before I wet sand them
80 on the interstate in heavy rain and could still see fine (camera doesn't do it justice)
2008 Eclipse GT
-Sun Sound and Leather Package
-BONE stock
1997 Mitsubishi Eclipse RS
-Cold Air with K&N
-Stainless 4-2-1 Header
-2.5" Catback
http://www.cardomain.com/ride/3012565
Old 02-17-2008, 01:06 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: HID Write-up (Projectors)
You didn't have to make some special bracket to mount the bulbs to the projector housing lights? All the others I've seen, people have had to make something for mounting them... What was the brand you bought?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-17-2008, 01:23 PM
Mine used an H1 bulb and the fit is so snug that they really weren't moving. and the bracket that was originally on the projector still works with a little bending. it popped off a few times because it was so tight, but i think they're staying for now. and the rubber cap that goes over the back of the projector is a pretty tight fit too so it helps. ill get some pics and post them in a few.
i bought my kit off ebay from seller "zgperformance" (24.99 plus 49.99 shipping)
2008 Eclipse GT
-BONE stock
-Cold Air with K&N
-2.5" Catback
Old 02-17-2008, 01:37 PM
ned032002's Avatar
ned032002 ned032002 is offline
I love how shipping is 2x as much as the cost to buy them.
Old 02-17-2008, 04:48 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Can you get any pics of the bulbs in the housing?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-18-2008, 12:41 AM
I know right?
I hit the remote start on my car about to head back to Greensboro and I heard a weird rattling noise (sounded like it was coming from right behind my header?) so I left the car at home and rode back with some friends so pics will have to wait til the weekend. Sorry guys, but I will do it.
2008 Eclipse GT
-BONE stock
-Cold Air with K&N
-2.5" Catback
