Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-17-2008, 09:03 AM
a_alyte a_alyte is offline
Unhappy Lower Tranny line leaking (minor at the moment)
'98 JGC (178K miles)
There appears to be tranny fluid leaking from my lower tranny line, which then leaks onto the lower rad hose right beneath it. When the vehicle is turned off, it will leak onto the ground about the size of a 1/2 dollar. I recently replaced my radiator & I had the same issue with the old one. My lower tranny line has a spring type clamp. Could it be the clamp? Any ideas appreciated.
Old 02-18-2008, 04:55 AM
dell520's Avatar
dell520 dell520 is offline
Send a message via Yahoo to dell520
Re: Lower Tranny line leaking (minor at the moment)
Mine leaked liked that when I first got it, good thing I had a warranty because the original clamp came off 2 different times allowing the hose to come off. The solution for the guys at the shop the second time was to put one of those screw clamp things on.
I would suggest this to you as well to make sure this doesnt happen. An easy fix for a potentially bigger problem later. Hope this helps ya.
Old 02-18-2008, 11:45 AM
I'll definitely switch the clamp first to see if that works.
