Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-16-2008, 11:40 PM
dntchke dntchke is offline
Cool 89 Regal Tail light issues need help please
I have an 89 Regal custom. Of the the 3 Brake lights (driver, center, passenger) The Driver side tail light does not light up when I hit the brakes but the others do. The tail light lights up when you turn the headlights on but does not vary in intensity when the brakes are pressed. any guidence would be greatly appreciated.
Old 02-19-2008, 05:48 PM
82Stang 82Stang is offline
Re: 89 Regal Tail light issues need help please
bad bulb driver side rear
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 03-12-2008, 05:42 PM
That was the first thing I had tried. It Turned out to be my turn signal switch. a few days later my signals stop working but would work in the defacto way that signals work when the switch has gone bad. it seems that the brake light/turn signal will illuminate when i have the turn signal pulled in some.
Old 03-13-2008, 05:56 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
All power to the 2 main rear lamps (not including the high mount stop lamp) is routed through the multifunction switch in the column. Since the M/F switch is a common issue on these cars, it's ususally the culprit when problems arise if it's not something simple like a burnt bulb or corroded socket.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
