Go Back   Automotive Forums Car Chat > Renault > Kangoo/Kangoo II
Old 02-16-2008, 03:49 PM
albeck albeck is offline
Kangoo 1.4 1999 non start
Hi
There's no petrol or spark, relaced the TDC sensor no luck, so sent the ECU to: Automotive ECU diagnostics who decoded the immobilizer and made it free running.
Fitted the ECU today and still a non starter, up to now that's £255.00, so I'm thinking of scrapping the car, before I do I thought I'd have one last try and see if anyone knows of anything else I can check?
The relays and fuses under the bonnet and dash look OK, there's no disable corrosion on the wiring connectors, I still suspect the ECU, no fault was reported on receiving it back from the repairers only that it had been decoded whatever that means.
The Kangoo was a very nippy good runner and last week just failed to start. Thanks Alan
Old 10-30-2008, 05:26 AM
choice choice is offline
Re: Kangoo 1.4 1999 non start
hi you have to disconnect the immoline first
second plug scanner
third :delete fauklt codes
4:reconnect immoline
5:start the engine when the immo light turn off
6 call me 0096170167119
