Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-16-2008, 10:07 AM
cpsquid cpsquid is offline
92 Boneville SSE Problems
Hello, I've got my fair share of problems lol.
First of all the oil sensor is going kinda crazy along with other sensors - just moving up and down really far while i'm driving even though the oil level is fine.
The climate control needs to be punched really hard to display and resets everytime the car turns off.
The cruise control doesnt work.
The brights came off of the little switch in the side of the steering column and i have to stick my hand all the way down to get to it.
Any ideas where I can get a new handle for the glove box?
The battery terminals are corroded to the point that when I hit a speedbump the car shuts off.
And I'm not sure if its with everyone but when my gas is below 1\4 the car shuts off when i turn corners or go on exit ramps.
Thanks for any help!
Old 02-19-2008, 07:12 PM
[email protected] i40741@aol.com is offline
Re: 92 Boneville SSE Problems
yup ours cuts out when we turn right, try replaceing fuel filter
Old 02-19-2008, 11:05 PM
Jrs3800 Jrs3800 is offline
Simply replacing the fuel filter will not correct the problem...
But if the filter has never been replaced your fuel pump may thank you for the filter change...
The Cluster freaking out could be dirty pins in the connector, or pins not making the contact they once used to causing the dash to get flippy..
The Tank has a set of Baffles, and in some cases the baffles have broken and this causes the fuel to run away from the fuel pump sock starving the fuel pump and engine for fuel... There is an updated filter sock for this, but even that may not fix the problem, in some cases you have to replace the tank to solve the problem..
Old 03-02-2008, 03:31 PM
pontiacfreak_81 pontiacfreak_81 is offline
Send a message via AIM to pontiacfreak_81 Send a message via MSN to pontiacfreak_81 Send a message via Yahoo to pontiacfreak_81
my 92 was doing the same thing, i had to replace the fuel pump and the fuel level sensor....never did it again after that
