Gas gauge sensor ground wire
I need to check the body ground connection for the gas gauge sensor wiring coming out of the gas tank. Any ideas where this is located? Thanks in advance.
Re: Gas gauge sensor ground wire
You should be able to follow the wire harness off the sensor and there should be a plug-in connector right close.
Unplug it and test the wire to the sensors housing |
Thanks. I pulled up the rug in the trunk and took the cover plate off that is over the top of the connections to the fuel pump. I dont see any connectors downstream of where the fuel pressure and fuel gauge senders are. Should I be looking somewhere else?
Thanks vey much for the info. I'll check underneath next to the tank for the ground block.
