Old 02-15-2008, 09:54 PM
moparcharger74 moparcharger74 is offline
1997 Lesabre Power Steering Pump Removal
I am currently in the process of starting to replace the Power Steering Pump on my 97 Lesabre. I know how to get all the bolts and hoses off, but I am having problems figuring out how to get the old pump out from behind the bottom passenger side of compartment. There doesn't seem to be enough clearance. Do I have to take some of the engine mount / stabilizers loose and rock the engine forward to get it out? In a TIGHT SPOT!
Old 02-16-2008, 06:59 AM
ghink ghink is offline
Re: 1997 Lesabre Power Steering Pump Removal
There should be a hole in the pulley. Rotate the power steering pump pulley to line up the mounting bolts. Then remove the pulley.
Old 02-16-2008, 07:22 PM
BNaylor's Avatar
BNaylor BNaylor is offline
"Then remove the pulley? Long ways to go before that is done. Don't you mean remove the power steering pump mounting bolts? A pulley puller is required to remove the pulley and that is performed while the power steering pump is off the car.
To the OP we have a tech procedure written up for a Regal but applicable to any GM car with the Series II 3800 engine at our Buick Tips & Maintenance forum. See link below.
http://www.automotiveforums.com/vbul...d.php?t=668484
Timeslip 08/12/06
AF Community Guidelines
Old 02-26-2008, 01:10 PM
Thanks BNaylor, lot of good info from the procedure you showed on the Buick Regal. Especially the Refill and air bleeding procedure (rack n pinion system). I ended up removing the Alternator and the Serpentine Belt Idle Pulley, and then I had enough room to pull the Power Steering Pump up past the passenger side of engine. Thanks for all the help!
