Old 02-15-2008, 09:59 AM
comet240 comet240 is offline
91 Voyager Bearing Problem?
hi a month ago i bought a bearing econonmy version has 1 year warrenty but now when i drive last past week its been crunching when i make a right turn like its tearing away gears so to speak and does make noises at certain rpms going straight
i took off the bearing but there is no play and its still tight, i gonna exchange it anyways but is it the bearing or is it the drive shaft?
or what woujld the driveshaft sound like if i were making turns?
its a 91 voyager 14inch tires front wheel drive
its the square style hub assembly
Old 02-15-2008, 02:03 PM
tempfixit tempfixit is offline
Re: 91 Voyager Bearing Problem?
CV Joints will make a clicking sounding when turning, meaning cv joints are going out. Check this site for what they look like:
http://www.napaonline.com/masterpage...ft+Front+-+New
Old 02-15-2008, 06:22 PM
ya i guess its the cv joint and i not gonna replace the section so ill replace the entire arm, so em i right that its the passanger side when i make right turns it crunches, here in canada at Canadain tire its 130 bucks but i think the wreckers in 50 bucks but i just hate doing it, cuz pain in ass to get lower control arm off the ball joint without damagaing the rubber boot
Old 02-16-2008, 09:55 AM
so what is easlier to do since i finnally got the drive shaft out
getting the replacement cv joint or replacing the entire shaft?
and since i had trouble prying out the lower ball joint out of the steering knuckle how will i get it back in again?
Old 02-16-2008, 12:09 PM
well i went to wreckers and they said there was nothing wrong with drive axel what it is it probably the driver side bearing, as the drive axel didnt have a broken boat. said older vechiles u could tell what side bearing problem was but newer ones u cant so i guess its the driver side boot ugh all that work and never the right tools
