Old 02-14-2008, 08:16 PM
Didymus Didymus is offline
Devcon 5-min Epoxy Doesn't Fully Cure
It doesn't happen all the time, but fairly often it stays pliable and I have to re-do the joint - which can be a messy proposition.
I normally do the mixing on a small sheet of Teflon. Days later, when I peel the leftover epoxy off, it's still gooey underneath. So it seems like I'm not getting a complete cure.
Most of the time, I need only a tiny amount, so I thoroughly mix a small dab of hardener with a small dab of epoxy. It's not perfectly half and half, but I come as close as I can. (Is 50 -50 really the best ratio? Or should I be using more of one than the other?)
When I first started using epoxy, I thought I wasn't mixing the two components enough. So now I go to some effort to mix them completely, but I stilll have the problem.
Ddms
Old 02-14-2008, 08:57 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Re: Devcon 5-min Epoxy Doesn't Fully Cure
If your having issues w/ it not hardening, I'd be inclined to include a little bit more hardener than catalyst. Just be careful b/c it could dry quicker than you expect.
Old 02-15-2008, 10:08 AM
ScaleTuned's Avatar
ScaleTuned ScaleTuned is offline
I use the same Devcon 5 min epoxy all the time, never had any issues. I always try to mix 50/50 ratio and it comes out perfect. If there isn't enough hardener, it will take longer to cure, but we are talking a matter of minutes, not overnight. If yours doesn't cure by the next day I'd say your way off on the ratio or you have a bad batch?
Old 02-15-2008, 10:49 AM
Yesterday I used a bigger dab of hardener. I clamped the joint just in time - it got hard in about three minutes!
That's better than it not hardening at all, because I can just mix up a new batch right away, instead of discovering a day later that the joint is still soft. So I'll continue using just a bit more hardener.
There sure is a lot to dislike about epoxy, but it does make a stronger joint than anything else.
Ddms
