Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-14-2008, 02:33 PM
Malachias Malachias is offline
Traction Light on
Bonny SSEi 1992:
After running a few blocks the dash show "TRACTION OFF"
I got a scanned code #74. Any ideas will be welcome.
Malachias (BRAZIL)
Old 02-14-2008, 07:42 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Traction Light on
Check that code again, "74" is not a good code for your car!
Old 02-15-2008, 07:55 PM
Dear HOTZ28 (AF moderator)
Thanks in advance for your quick answer. The code " 74 " was grab by a
OTC scanner and match with the GM code chart.
I did it again with the same results and the mecanic show me a GM Corp chart where I could see the ABS/TCS fault codes chart # 74 meaning a
PMV Pressure Switch. He said that I have to buy a whole pump regulator with traction control because there is a bad internal valve (Solenoid) and itīs a sealed parts with no rebuilt here in BRASIL. The part has a PN#25653459
(ABS HIDRAULIC UNIT). Do you agree with it?
My best regards
Malachias (BRAZIL)
Old 02-15-2008, 08:29 PM
My best regards
Malachias (BRAZIL)
xxx
Old 02-16-2008, 01:32 PM
HotZ28's Avatar
AF Moderator Elite
Yes I agree! Sorry, to begin with, I was in a rush and was not looking @ GM ABS/TCS codes, instead I was looking @ engine/trans codes.
CODE 74 = PMV PRESSURE SWITCH CIRCUIT NOTE: (TCS ONLY).
Old 02-16-2008, 07:15 PM
Dear HZ28
Thanks again for your imputs and help. I`m going to order @ GM Worldwise Parts this ABS HIDRAULIC UNIT a 700.00 bucks part plus $$$$ for S/H to Brazil. Looks this people wants to rip me off!!! but what to do?
I wanna shut off this idiots light from my dashboard.
My best regards
Malachias (BRAZIL)
