Old 02-14-2008, 05:54 AM
stymie51 stymie51 is offline
98 caravan window regulator
the window on the pasenger side dosnt go up or down, i took the door panel off and saw wires going to the regulator how do you get them off thanks
Old 02-14-2008, 11:58 AM
tinner105 tinner105 is offline
Re: 98 caravan window regulator
Send me a PM with an email address and i can send you info from ALLData.
Are you looking to just remove the power going to the motor to test for power?
If thats the case there usually just some sort of clip that need to be pressed to release the connector.
Here's the procedure for testing the motor if theres power
Power Window Motor Test
If the power window motor is receiving proper current and ground and does not operate proceed with motor test.
  1. Remove front door trim panel and water shield as necessary to gain access to power window motor wire connector.
  2. Disconnect power window motor wire connector from door harness.
  3. Using two jumper wires, connect one to a battery (+) source and the other to a good ground (-).
  4. Connect the Negative (-) jumper probe to one of the motor connector terminals.
  5. Momentarily touch the Positive (+) jumper probe to the other motor connector terminal. When positive probe is connected the motor should rotate in one direction to either move window up or down. If window is all the way up or down the motor will grunt and the inner door panel will flex when actuated in that one direction.
  6. Reverse jumper probes at the motor connector terminals and window should now move in opposite direction. If window does not move or grunt, replace the motor. If window moved completely up or down, reverse the jumper probes and cycle window to the opposite position to verify full operation. If motor grunts and does not move, verify that regulator is not binding.
If you ned anything else just let me know.
Tony
