Old 02-13-2008, 09:32 PM
Andrew Martin Andrew Martin is offline
Illuminated entry..... again
I posted a while back on the car's interior lights not going off. They're time-delayed, so they're supposed to slowly start to dim after the door shuts until they're completely off, and they're also supposed to turn off instantly when the key is turned. However, they just stay on constantly. For about 20 minutes before they turn themselves off. (I'm not sure, but the manual says "If there is a problem in which the lights stay on, they will automatically shut off after 20 minutes to avoid battery drain")
I believe xeroinfinity replied and said to try checking the door jamb switches, but there are none that I can find on the front doors. There are only jambs on the back doors, and they don't even turn the lights on when opening the doors. The front passenger doesn't either, so it's just the driver's door that seems to be responding to being opened, and it's the only door that turns on the lights at all.
This is a really minute problem in the grand scheme of things, but it still irks me. It makes sense that a door jamb switch would be causing the problem, but finding it is the speed bump. Can anyone help? Thanks. =]
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 02-13-2008, 11:30 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Illuminated entry..... again
Thier is a switch inside the door latch which signals the light on.
If thats good, then thier is a small box that controls your lights, might be called the dimer module.... I forget...
Its located by your steering column, not more the a 2 inch square.
1999 Grand Am SS 3.4 OHV
Old 02-14-2008, 08:44 AM
Alright, where around the steering column?
I just hope I can get that column cover off without breaking it. lol
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 02-19-2008, 11:22 PM
Update: This might specify problems a little bit more.
I went in through the passenger door simply so the lights wouldn't come on and I turned the dimmer knob all the way up to where the interior lights were supposed to light, but they didn't.
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 02-20-2008, 10:41 AM
Now that sounds like your dimmer switch is malfunctioning.
Have you checked your fuses ??
You can remove the switch and check that the plug in is connected and check for power.
Old 02-20-2008, 12:43 PM
Fuses are all good.
So the little dimmer knob is bad?
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 02-20-2008, 04:59 PM
not the knob , it would be the whole unit if that's what's wrong.
Did you ever find the dimmer modul under the dashclose to your steering column ??
That's most likly whats blown, it can happen when installing aftermarket stereos...
Old 03-04-2008, 04:04 PM
Exactly what does this module look like?
And where in relation to the steering column is it? Thanks
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-04-2008, 05:53 PM
its about 1/2" thick, and a 2" square.
Could be on either side of the steering column.
You'd need to remove the kick panels to find it.
Old 03-04-2008, 07:36 PM
Umm..... *looks down to my feet, face turns red*..... what are kick panels? =@ lol
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-04-2008, 09:59 PM
are you sure you want to work on this lol
Its the panels just above your feet when sitting in the seat.
Usualy numerous 7 - 8 mm bolts holding them on, or a few plastic push pins.
The device you are lookin for is on the right, though it can be moved around. Dont even know for sure if you can buy a new unit.
Old 03-15-2008, 11:38 AM
Who would buy a new one anyway when there's a junkyard 5 miles down the road? =D Heheh
So it's a little black box-shaped module off to the right?
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-17-2008, 03:01 PM
Ooooh! Okay! I know what kick panels are now. What stumped me is that my car doesn't HAVE one on the driver side. heheh
I'm having a hard time finding whatever this stupidass thing is.
I found a little thing that looks like a miniature solenoid bolted into a heatsink and un-plugged it; no power then went to the instrument panel lighting. (Dome lights still on.) I changed it and the dome lights still won't work right.
I really need whatever this part is in as great of detail as anyone can tell me. Colour, size, shape, how many wires going to it, what colour are the wires going to it, etc. etc.
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-17-2008, 04:01 PM
The module is located on the left side of the instrument panel, near the brake pedal. It has 3 wires , it is mounted on a heat sink and usually attached to a metal bracket.
YEL - wire is power feed from INST LPS fuse
DK-GN - wire is control signal from dimmer switch
GRY - wire is the output to bulbs
Dimmer Asm - I/P LP GM P/N 1995263 ACDelco P/N is #D1509B
IT costs about $20 at a stealership.
Though this might not be your troubles, you should check that your door switches are working, they are the ones that turn the lights off and on.
Oh yeah, here is a pic that might help, its #1.
Good Luck!
Old 03-17-2008, 05:28 PM
That's what I replaced, but still no workie. =[
Think it's possible that the one I got was no good either? =\ It came out of a junkyard car.
Do you have any good diagrams on where the door switches are and what they look like? There's no actual button on either front door like on the back.
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
