Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-13-2008, 06:59 PM
Siouxicide Siouxicide is offline
Blowing intake hose off post-turbo '98 GS-T
Kind of a two-part question. I've tried turning the boost down on the EVO III big 16g but I'm not sure if I'm getting anywhere. What happens is occasionally, under boost(not sure how high but seems to be >17lbs) I'll blow the rubber hose off that clamps to the ducting off the turbo and ducting into the intake. Of course when that's off I can hardly drive the car.
What I worry might be causing this is the injectors are still stock and I'll get fuel cut around 4,500rpm. When it cuts, will it also block the flow of intake air causing it to blow the hose off or am I just pushing too much air in? I doubt the intake air gets blocked.
Also, with high-flow injectors, is it truly necessary to get the DSM-link or anything like that for mapping, etc?
Old 02-13-2008, 07:06 PM
steviek's Avatar
steviek steviek is offline
Re: Blowing intake hose off post-turbo '98 GS-T
Ok first 17 psi On the E316g Is WAY to much on the stock fuel system. You should really only be running a max of about 12 on that turbo. No your fuel cut isn't causing your intake (or intercooler pipe) not too clear which one you are talking about to happen. To solve the problem get better T bolt clamps and bolt them down TIGHT so it doesn't happen again.
Finally yes you will need a SAFC or link to compensate for bigger injectors or a maf-t works too but not worth it and difficult to tune. If you don't you will be constantly running rich and get terrible power and economy. Not to mention stock 2g fuel pump doesn't go that far either.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-13-2008, 07:09 PM
steviek's Avatar
"Hey thor he is from minnesota maybe you got another one for the dsm north meet
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-14-2008, 11:52 AM
Thanks for the reply. The ducting I'm talking about is on the boosted side of the turbo. Turbo to intake manifold. There's a rubber sleeve connecting two steel "ducts". I have some really stout clamps on there. The kind you use a wrench to tighten, not a screwdriver. And I'm still blowing that off.
Personally, I think(well I know) I have too much boost coming off the turbo. I've tried adjusting the boost controller way down. Seemed to make no change. I've tried adjusting the BOV. No change that I can tell.
Does anyone know of a base setting for the boost controller or BOV? i.e., crank it to the stops and then 3 1/2 turns out or something like that? I have no manuals. I'm planning on just de-rating my turbo down to 10-12lbs like stock so I can go WOT without fuel cut.
Old 02-15-2008, 11:48 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
16g turbos are real bad about boost creep. If your MBC doesn't seem to be effecting the boost level then you are problably getting boost creep. You need to port the turbo to fix it. Also I dont know to many people who can run 12psi on that turbo no matter how much porting is done. I dont think the internal wastegate flows enough to keep the boost down that low.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-05-2008, 12:17 PM
Noob question....how do you go about porting the turbo? Also, without DSM-link is the performance that bad? I'm just trying to get it to stop fuel-cut so it won't spook the hell out of someone interested in buying it. But if it runs like trash that'd be counter-productive. What would be the suggested injector flow capability for a big 16g turbo? thanks
Old 03-05-2008, 12:53 PM
steviek's Avatar
Well a maxed out e316g needs about 720cc's (stock 450cc) to still be on the save side. You may be hitting fuel cut or you may be hitting an ecu maximum value of 2.1g's of air /a revolution. At this point the car will jerk back it will feel like you hit something almost. The stock 2g ecu has a limiter which is designed to protect the car from overboosting (basically it was installed so that people didn't blow their engines while the car was still under warranty). Its hard to tell which problem is yours. If the engine hits a certain rpm level all the time under the same WOT and it jerks back then you may be hitting the limiter. If the car gets up in the rpm and then begins to shake violently and lose power and acceleration then it is more likely fuel cut.
About the porting. If you have to ask you probably shouldn't do it. It is a painstakingly long process. You need a air compressor with a carbide tip and it takes hours to gasket match and smooth. Not worth it normally for non enthusiast.
What you can do to help fuel cut is put in a walbro 190 fuel pump. It will improve the cars ability to have higher rpms without jeopardizing fuel economy on the lower end and is ok with the stock fuel pressure regulator. They are 90 bucks. If I were you I would put the boost controller on full close and see if you notice any boost reduction. If not your problem is likely just your wastegate not opening soon enough. Either that or maybe your boost controller isn't installed properly. Try hooking your wastegate straight to the factory boost control solenoid located underneath where the Air sensor is. It looks like to little nipples.
Good luck
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-05-2008, 12:57 PM
steviek's Avatar
also if you are unclear about which parts are where or anything like that refer to this guide
http://members.shaw.ca/dsm.1000q/Engineprimer/
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-05-2008, 01:09 PM
I was told the car has an aftermarket fuel pump. It does make a noticeable whine/hum. Maybe that's not normal.
Most times when the engine cuts, it's just one sudden cough. I lift off the throttle(simply out of reaction) and then back into the throttle. One time I thought I blew something right off the engine. Not so I found. But mostly it's just up to 4,500rpm and "poof". So you're saying even with 720cc injectors I will likely hit the limiter for the ecu?
You're right, I won't be messing with porting the turbo. I do have a Greddy boost controller though and I'll try to back it all the way down.
Old 03-05-2008, 01:22 PM
This is a list of what I know that I have:
1G engine, E3 big 16G turbo, intercooler, cold air intake, Greddy BOV & boost controller, Apexi N1 downpipe, EVO III O2 housing, 3" turboback exhaust
What's the easiest way to post photos on here? That might be easier for everyone to see what I'm talking about.
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
are we talking an electronic boost controler or manual? i can have my gate open at 10psi, and i only creap a hair past 15psi at redline... (but mine IS ported...) actually, i can set it as low as 7 psi... but i still end up at 15psi at redline... so i just tuned for 20psi
Old 03-05-2008, 01:41 PM
Manual. Takes a hex wrench. There are two modules I can adjust. One says Boost +/- and the other BoostXs, if I remember right.
Old 03-05-2008, 02:00 PM
steviek's Avatar
best way to host photos is via photobucket.com
turn the boost controller all the way to the - side and see what happens/
The fact that you have an aftermarket exhaust and o2 housing doesn't help for trying to keep boost down as they do open things up a ton.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-05-2008, 02:01 PM
steviek's Avatar
I used to hit the g/rev limiter on the e316 at 24 psi in third at about 5500 rpm or so on 550cc's injectors. It was really annoying as it prevented me from getting any good 1/4mile passes in.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-05-2008, 02:21 PM
Black99GST's Avatar
do you have access to a tire pump/air compressor/anything of that nature? this my sound funny but this is what i do to set my boost controler...
pull it from the car with the vac lines attached to the boost controler.
hook up the boost side (usually the side, and opposed to the bottem) hook the line up to your pump.
push the pump/air compressor and keep your eye on the pressure gauge you will here when the boost controler opens be sure to have the hand twist adjustment turned 5-7 times (+), then adjust the hex screw as needed to reach you desired boost pressure (low teens in your case)
then start the drive, adjust, drive method for fine tuned boost pressure
this takes about 3-5 mins and is much faster then the drive, ajust, drive adjust method alone...
keep in mind your turbo is still creeping, so just because the gate is open doesnt mean your boost will hold steady...
as for the pipe blowing off, nothing a little hair spray and come elbow greese cant fix! spray that bitch down and clamp the hell out of it! do you have a beeded lip(buldged up at the ends) if not this could be your problem... you can just frey the pipe outword with some vice grips... works GREAT!
