Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 02-13-2008, 04:33 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Anyone use a Motive power bleeder?
Curious if anyone has one and has found the proper cap to get a good seal? I want to buy one so I can bleed the brakes quickly and alone.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 02-13-2008, 10:47 PM
02Panoz 02Panoz is offline
Re: Anyone use a Motive power bleeder?
Yes, I use one. You can go to the company web site and order one with the correct adapter to work on the Panoz. My Esperante uses the 3 prong but you should check you brake fluid reservoir to see which you need. http://www.motiveproducts.com/01products.html . I also like the ATE brake fluid. It comes in clear and blue so you can alternate years and know when you've flushed out the entire system.
Old 02-15-2008, 11:05 AM
panoz302 panoz302 is offline
I have a new one in the box extra I will see if it fits tonight, I like the product but you have to buy the better head attachement that swivels. I think it is the black label which I have.
