Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-13-2008, 03:38 PM
Shells_k Shells_k is offline
2WD, 4WD, Part Time 4WD?
Okay, I have never driven 4WD before getting my JGC. It really came in handy driving home in a bad snowstorm last night. I dont really understand the whole 4WD thing though, especially when looking at the Shifter. I have 2WD (which I have kept it in until yesterdays big storm), Part-Time 4WD, Full-Time 4WD, and Low. Can someone explain the differences to me, and when it is appropriate to use them?
Also - A buddy at work said to makes sure I dont keep it in 4WD all the time, because if I use it on dry pavement I will ruin the Jeep?
Old 02-13-2008, 08:22 PM
95zj-tilshedies 95zj-tilshedies is offline
Re: 2WD, 4WD, Part Time 4WD?
Your transmission case (TC) is the 242:
2WD = two back wheels turn (drive in this mode most of the time to get the best gas mileage)
Part-Time 4WD = all four wheels turn all the time (use this on wet or loose roads ONLY [you can only use this PART-TIME] -- because all four wheels are locked (they are all getting power, the road must be wet or loose [dirt, gravel, snow, etc] to allow for the front wheels to continue to have power --- your friend was right: don't leave the TC in this mode or you can damage it)
Full-Time 4WD = you can leave the TC in this mode all the time if you wanted to (thus, FULL-TIME). While still 4WD, the front wheels are controlled by a limited slip differential in this mode, making it safe to use on all road surfaces.
LOW = or 4LO -- this is also 4WD, but you should really only be using this in pretty extreme circumstances, and the Jeep should not be driven more than about 5 MPH in this setting (also only on loose or wet roads).
BTW, this may be printed on the back of your driver's side sun visor.
Hope that this helps.
-Steve
'95 ZJ -- 4.0L Selec-Trac stocker (~150,000) --- SOLD
'93 XJ --- RIP '04
"Excellence that must be proclaimed, by the mere fact of its proclamation, admits the doubt of its existence”
Old 02-13-2008, 09:54 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
While the last post is basically correct, just wanted to make these 2 points:
In any Part Time mode, either 4hi or 4lo, the center differential in the transfer case is locked, and the front and rear axles turn at the same rate. These modes should NOT be used on dry pavement. The owner's manual says that 4LO should be used at less than 25mph. If you want to go faster, keep an eye on the tach and remember that you should only shift into or out of 4LO at 3-5 mph or you'll damage the transfer case.
In Full Time, the center differential allows the front and rear to turn at different speeds, so as 95zj said it can be used all the time if you like.
Most GCs don't have a front limited slip differential.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-14-2008, 08:39 AM
Thanks so much for the info guys, I sure appreciate it!
