Old 02-13-2008, 01:47 PM
nlohman0717 nlohman0717 is offline
blazer not starting
I have a 95 chevy blazer 4.3 4wd. Every now and then it will not start. It cranks and sounds like its going to start..but just keeps cranking...and no matter how many times I try it wont start. other days I will go outside and it will start right up with no problems. Im getting pretty frustrated. I took it to advance auto and had them scan it but the only code that came up was P1442.
Old 02-13-2008, 04:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: blazer not starting
1442 is a OBD2 code for emmision system leak.
Clear code and check gas cap first thing.
No fill up with engine running and give the cap 3 clicks.
On the starting check cold cranking fuel pressure.
If a 4.3 W engine code you need 59-60 lbs on cold cranking to squirt injectors.
Fuel specs is 55/61
While the gauge is hooked up check engine running on the road pressure to.
Post back fuel pressure readings.
MT
MT
Old 02-13-2008, 08:29 PM
How do I go about checking the fuel pressure...I'm pretty good with cars but I'm really not sure how to do that.
Old 02-13-2008, 10:11 PM
82Stang 82Stang is offline
P1442....EVAP monitor circuit/vacuum switch high voltage
Try unhooking the pos and neg leads from the battery and clearing the codes for a few minutes. Then run it and rescan for codes. Could be as simple as a bad gas cap or something more. i.e. bad canister purge valve.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
