Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 02-13-2008, 12:15 PM
merlebh merlebh is offline
89 Supra non-turbo starting problem
My 89 supra non-turbo has trouble starting when cold after sitting more than about 10-12 hours. Turns over fine but will not start. After a few minutes it will shake and spudder like it is trying to run on half the cylinders then it dies and white smoke comes out from the air filter. Eventually it will start and run fine. I just started having this trouble during the cold winter weather. Occasionally after it starts it will hesitate on acceleration. This usually only lasts a few minutes.
Old 06-30-2008, 03:29 PM
jd120168 jd120168 is offline
Re: 89 Supra non-turbo starting problem
If I were you I would check my mass air. Clean it with a good cleaner made for it, let it dry then see if it helped. If so you probably will be replacing it in future.
