Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-12-2008, 04:43 PM
Florida240sex Florida240sex is offline
92 240sx Acceleration problem.
I bought my car about a year ago, when i first test drove it it ran great, it was pretty peppy and put a smile on a 16 year old's face. Anyway it sat for about 6 - 8 months while i was gathering the cash for registration/insurance, once i finally had enough and got it on the road it was much slower than it was before. What's happening is that when i accelerate it kinda bogs down, when i rev it in neutral it's fine, if im driving on grass or loose dirt it also seems much better, it seems to only be a problem when it's under load. I did a burnout with it when i first got it just for S's & G's and it suprised me, so after i got it on the road and started noticing this problem i decided to rev it up and pop the clutch, and upon doing this the tires let out a quick chirp and the engine bogged down almost to a stall. Also when i first got the car i took it up to the spped limiter (115), and now i can carely get it to 100. Don't get the wrong idea im not a crazy jackass driver, i don't haul ass in heavy traffic or in mild traffic for that matter, any time i ever go fast is on a backroad with no houses or poeple that could potentialy be hurt and iv'e only done this a few times just to compare it to the way it was when i first bought it. Now iv'e already replaced the fuel filter aswell as the cts (coolant temp sensor) and it's not a clutch problem, so if anybody can give me advice on what could possibly be causing this i would really appretiate it, i want to do a ka-t build with it but not untill i solve this problem.
Sorry for the double post, but the technical forum doesn't seem very active.
Old 02-13-2008, 03:17 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: 92 240sx Acceleration problem.
ummm thats a pretty vague description. thats the hard part about forum help. most people dont have a clue, and those who do fix it themselves. that said, is it running on all 4 cylinders? do you have any DTCs? just my intuition, i would look to see if all the injectors are functioning properly. then do a compression check, spark check, fuel pressure check, and timing check. let me know what you see from these tests.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 02-13-2008, 06:20 PM
Yes it's running on all fours, there are no problems that the dash indicates, how would you go about testing the injectors? Iv'e already done a compression check, on cylinders 2-4 i got about 175 on each but only about 165 on cylinder 1 wich makes me wonder if maybe the rings are a little worn? Also how do you go about doing a fuel pressure check? And i figured since im not getting any misfires and it's running on all cylinders my ignition would be fine, i havn't adjusted the spark timing at all so i don't see why it wouldn't be. Anyway thanks for the input!
Old 02-15-2008, 12:01 AM
842skyline 842skyline is offline
How does it crank over???
Old 02-15-2008, 02:47 AM
Just fine, like i said it only seems to be a problem when it's under load.
Old 02-15-2008, 04:54 PM
if your running on all 4 cylinders, it seems like its a fuel management/engine sensor issue. if your gonna tackle this yourself i recommend at least getting a chilton manual. i dont think in 92 that the dash had a check engine light but im not 100% sure. you should be able to manually pull any codes from the CPU using a method in the previously mentioned repair manual.
Old 02-16-2008, 03:37 AM
Alright thanks! Ill look into that right away!
Old 02-19-2008, 12:18 AM
I did a self diagnotsic check using the ecu and it gave me code 55 (nothings wrong) Wtf!? Anybody know something else that could be causing my problems?
Old 02-20-2008, 10:47 AM
are you sure its not a clutch problem? or a CMC problem? sorry for the swing and miss its hard to diagnose things over the net.
Old 02-20-2008, 04:58 PM
It's possible it could be the clutch i guess, it just doesn't seem like it. A while back i was adjusting my pedal to shorten the throw and several times i had it were it didn't engage all the way, so i know what it feels like when it's slipping. But i suppose if it's off by even a little bit it would definately affect the top speed and acceleration, i guess ill find out when i replace it, for now there's nothing i can do but hope that's what it is, cause at least it would be an easy fix.
