Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-12-2008, 07:31 AM
klvaleri klvaleri is offline
Thermostat
Hi Guys,
My SUV's heater is not getting any warmer like it use to have it. It is just a little bit warm that is it. I check my anti freeze and it is full, one thing that I knew while checking the anti freeze is that my upper hose is warm and lower is kind of cold and it's been running longer than 30 minutes already. I don't know much about heater system but I think my thermostat is not open. Can any one help to diagnose this heater system. How difficult to replace a thermostat in my SUV if it is bad "1999 Isuzu Rodeo 3.2" Thanks for advance.
1999 RODEO LSE 4WD V6 3.2L
Old 02-12-2008, 11:21 PM
Ramblin Fever Ramblin Fever is offline
Re: Thermostat
I'm not sure how difficult it is in your year, I do know it's under the intake manifold.
Does sound like you need to replace the thermostat as well as radiator/coolant flush, sounds like the cooling system may have a blockage as well.
Make sure you ABSOLUTELY use an OEM Isuzu thermostat ONLY.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 02-13-2008, 06:49 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Thermostat
If its not heating up the t'stat would be sticking open, not closed. A t'stat stuck closed would make it over heat. What does the temp gauge say? One hose should be cooler then other, thats the job of the radiator. If your gauge is getting to normal but you arent getting heat, check the 'doors' on the heater core. These dont have valves on the heater core, just doors that mix the hot and cold air, they can come out of adjustment.
I havent done a t'stat on a rodeo yet but on 2nd gens ('98+) the t'stat is indeed under the intake plenum. Which means the plenum has to be removed to get to it. That means you probably will need new gaskets for it as well.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
