Old 02-11-2008, 09:42 PM
studdly studdly is offline
1991 caravan starting problems
the starter is trying to start even when the key is off. It already fried one starter. Would it be the ignition switch suck on the start postion???
Old 02-11-2008, 10:28 PM
tempfixit tempfixit is offline
Re: 1991 caravan starting problems
Have you tried removing starter relay? It is located under hood, passenger side above strut tower on fender well in the relay box.
Old 02-11-2008, 11:17 PM
no i havent tryed that. thanks i will try that. is it a common problem on these things?
Old 02-12-2008, 12:48 AM
Arent you sure its not the ignition switch??
Old 02-12-2008, 01:50 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Nobody can be sure of anything if they can't get their hands on it. You'll have to troubleshoot. Do you have a voltmeter/multimeter and have an idea how to use it? Come on back.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-26-2008, 11:55 AM
thanks for the replys but it was a faulty starter. what i did was removed the relay, unplugged the wire harness from the igniton switch in the steering colum and it still started. the starter was stuck in the start postion. just changed starter and its fine..
