Beretta Door Pin Switch location
OK Beretta people I need a little help......
My daughter has a 1994 2.2l Beretta that suddenly doesn't turn off the interior lights when you shut the doors. The repair manual references front door switches in the wiring diagram, but I don't see where they are when I look at the door. What am I missing? Thanks, Newb45 |
Re: Beretta Door Pin Switch location
Removed by Moderator |
Thanks for the response loosenut. I had already checked the position of the dimming switch- but I still have to check it electrically in case it somehow has a dead short.
As for the pin switch- I still don't see one on either door, or mating surface. I did see a black and a white wire going to the passenger side door latch. I think there must be a door-ajar switch in the latch mechanism. I will have to tear into that now. Thanks again newb45 |
no problem, if your still having problems after that, check the signature, join the site therein, I will help you in any way I can...
