Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-11-2008, 08:53 AM
gramma gramma is offline
Question '05 2500 burb chirping noise
I bought an '05 burb and after a month or so there was a chirping noise in the engine. Took it to my mechanic's I call the boy's and they replace the alt. belt and tightened some torque thing. It was fine for a few miles then it happened again. Put on a new belt and after a few miles it was back. They think the belt might be the problem, it is not GM replacement. Could that be it or should they look for something else. They are both Chevy truck lovers and they say they have never had this happen to them. Can you give me a hint at what it might be so I can act like I know something and talk the talk.
Old 02-11-2008, 09:38 PM
j cAT j cAT is offline
Re: '05 2500 burb chirping noise
this is usually a pulley bearing. do the boys have a stethoscope ?
Old 02-12-2008, 08:58 AM
Smile Re: '05 2500 burb chirping noise
thanks j cAT, I will ask about the bearings. You are the only one that had any idea what it may be. Hope you are correct. Let you know later. Gramma
Old 02-12-2008, 04:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
If no stethoscope, a long screwdriver works just as good.
Spin all the pulleys with the belt off. If any make noise, you've found the problem.
If it is actually the belt, I would replace it with a GoodYear Gatorback belt. I've never had one make any noise. If you narrow it down to probably the belt, spray it with brake cleaner while it's running. If the noise goes away, it needs a belt. If it doesn't go away, spray it with silicone lubricant. If the noise goes away, it needs a belt. If neither affects the noise, it's not a belt problem.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-12-2008, 04:43 PM
j-ri take note that silicone use while engine is running is not a good idea as this chemical is damaging to O2 sensors....
Old 02-12-2008, 07:04 PM
Thanks guy's. I am having a new belt put on tomorrow. It is a Goodyear but I don't know if it is a Gatorback. What is the diff?
Old 02-12-2008, 07:16 PM
It don't matter. just make sure they put in the correct belt.. if the belt is too short it will stress out the pulley bearings. I have had intermittent idler pully bearing noise for 7 years now. but it also could be a belt that is getting hard making some noise i can't tell from here what it sounds like..if the belt has cracks in it and/or its 3years old and 50,000mi i'd replace it....
