Old 02-10-2008, 06:01 PM
74hotrodmalibu 74hotrodmalibu is offline
Question Daytime Running Lamps
please i have seen this beofre in other board DONT SAY I THINK I KNOW WHAT YOUR PROB IS..............THIS IS FOR THE SAFETY OF MY WIFE DRIVING AT NIGHT ...............when put in gear (no headlights turned on) the DRL's wont come on, but will let her have low beams and pass side high beam only i know its either a short or maybe the drl relay under the battery tray. My question for SOMEONE WHO HAS FIXED THIS PROBLEM NOT SOMEONE JUST CHIMING IN i am sorry if i come across harsh , BUT TIRED OF PEOPLE SAYING JUST CUT THE WIRE for the drl's if i wanted to do that i would not be here on this board i need to know what fixes this and/or cant we get a petition going around(electronic one) for GM to fix this since after the 8 year mark of the car (and sometimes newer) THERE SHOULD BE A RECALL FOR THIS WHY WAIT TILL A HANDFULL OF PEOPLE LOSE THERE LIFE TO FIX SUCH AN EASY PROB DOES IT TAKE A MULTI MILLION DOLLAR LAWSUIT TO ADDRESS A PROB LIKE OR WHAT.........
Old 02-12-2008, 10:02 AM
homerr homerr is offline
Re: Daytime Running Lamps
You did not mention if you changed the head light.
Old 02-12-2008, 11:17 AM
muff34 muff34 is offline
Ya Too harsh sorry for your luck. If you want it fixed properly TAKE IT TO A GM GARAGE. After all it is YOUR WIFE`S SAFETY AT STAKE HERE. You are right cutting the wire does not correct the problem ,however you`ve read the forums and can see that others have had similar problems. So you can do as others do and take the radiator cover off and pull the battery out and whatever else needs to be moved and inspect the wiring and connections . Someone who has done it will tell you this then someone will tell you to change the DRl relay and then someone else will say change the Multifunction switch all these things have been done by others and have corrected their problems.I am waiting for warmer weather to correct this problem also ,so you are not alone! Good luck
Life Is A Highway ,Enjoy The Ride
Old 02-12-2008, 09:10 PM
i knew it would be too harsh for the meak but those of us who can handle a lil harshness with our breakfast know where i am coming from......i have already had it a dealer AT OVER 75 AN HOUR 2 HOUR MINIMUM AND IT TOOK THEM 4, they changed the relay, switched out lights,changed the drl relay under the battery tray, they didnt have a switch in stock to change the turn signal one out but i am gonna be safe and say thats it for my problem ...THATS THE ONLY THING LEFT FOR ME TO CHANGE and another 44 buxs isnt gonna kill after what the dealer did i hate dealerships they are the den of the devil
Old 02-12-2008, 10:59 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Yep, i've been in your situation before. Seen this a few times and i know the cars wiring inside and out.
1) I replied with just killing your DRL's because your not going to want my answer.
2) Go find yourself a new headlight wiring harness ( the fault is in them) Its slowly fluttering down through the years as the cars are getting older. I've had to do this on a 96, 97, 98 so far. The lights became intermittent, DRL light flashing in the cluster. Wiring harness always cured the problem.
OKAY?
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 02-12-2008, 11:24 PM
OKAY? i havent lost any of the lights except when she turns the brights on the left one goes out (drivers side) and this didnt happen till a day after i put a wal mart bulb in my turn signal ...coincedence?? i dont think so!!!!......... well maybe but i have never been able to use that till now LOL where besides a dealer can i get one of these harness's and is it just the headlight harness?? or what harness??
Old 02-12-2008, 11:32 PM
and befiore it gets out of hand i was just being funny like you with the okay being big .........thanks for helping me out on this matter also my friend
Old 02-13-2008, 03:23 AM
your killin` me with this one my friend....lol ,I`m a night shifter and don`t eat breakfast. After you`ve changed your switch why not take Classicrocjunkie`s advice and do the problematic wiring harness. good luck with your car, no hard feelings here man
Old 02-13-2008, 03:39 AM
Originally Posted by muff34
your killin` me with this one my friend....lol ,I`m a night shifter and don`t eat breakfast. After you`ve changed you switch why not take Classicrocjunkie`s advice and do the problematic wiring harness. good luck with your car, no hard feelings here man
ok if thats not the prob where and how much do i need to bend over for this wiring harness for the lights??? he signed off before he answered me ?? dangit
Old 02-13-2008, 07:24 AM
Lifted GMT-360!
It depends where you find the new harness. I've snagged a couple on e-bay or www.car-part.com. for 15-20 with shipping. If it comforts you any wait a couple days and i'll have my GM factory service manuals on hand that i paid out the ass for and i'll double check in that what it says to do. But i will tell you right now there is a short somewhere in the headlight harness. It could be a bad ground, bad connection somewhere in the harness with one of the pig tails. But seeing there are 4 pig tails 9005 and 9006 buy the time you went out and bought all new ones the cost of a new harness is cheaper than buying all of those.
If you got the time, get a volt meter and check the voltage going inside the hot side of the pigtail with lights on to see if its even getting power which it probably is but no ground. There is 3-4 grounds bolted into the frame under the battery tray, its also possible one of those is corroded away. I hate the 95-99 wiring harnesses, they were poorly designed and having nothing but problems with age.
Old 02-13-2008, 12:34 PM
this solved my problem so far so good .......................... Here goes...
-Disconnect the negative battery terminal.
-Remove radiator cover.
-Remove headlights and turn signals.
-The problem occurs where the wiring runs across the car in front of the radiator. The wires rub against the bumper supports, causing pinholes in the wiring that corrode.
-Unwrap all the wiring that is there. GM does a really insufficient job of protecting the wiring.
-Once you locate the pinholes all you have to do is replace the section of wire that is bad. I personally had 1 on passenger side and 5 on driver side.
-Once you do that just wrap all the wiring in GOOD electrical tape.
-I went a step further and also used plastic wire loom to protect against the wear of the rubbing.
-Then just reattach the wiring and put everything else back together.
-Problem solved!
Old 02-13-2008, 12:36 PM
and especially since the mrs has been in the ditch once and ran into a snowdrift a 1/2 mile from our house dam drift was right around 2.5 feet tall DONT KNOW HOW she didnt see that at night
Old 02-13-2008, 12:40 PM
but you can still send the info just in case i have another prob that pops up and if you wanna email it you can to [email protected]
Old 02-13-2008, 02:28 PM
-Problem solved!
Lol......... good deal but this reads like this http://www.automotiveforums.com/vbul...adlight+defect. I believe in giving credit where credit is due and that would be this fella ......lol. Glad you got yours repaired ,wanna come north amd do mine for me ? It`s too cool for me with this type of work.
P.S . I`ll keep an eye and ear open for the Malibu parts you are looking for as per our discussion this Am
Old 02-14-2008, 04:03 PM
Thumbs up Re: Daytime Running Lamps
see my post i did not take credit i simply followed his directions..I NEVER SAID IT WAS ME.....................i just reposted the important stuff i wish i knew who the original poster was cause i buy him or her a few rounds
