Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-10-2008, 04:47 PM
bcownie bcownie is offline
95 Regal won't start after sitting
I have a 95 Regal with a 3800. If it sits for a couple hours or more it doesn't want to start. I've checked the fuel pressure at the regulator and have between 40-45psi with just the key on. I plugged the return line and it went up to 75psi. I left the guage on overnight and had 10psi in the morning. After it sits if I spray a quick shot of carb cleaner in it, it starts right up. After it started the fuel pressure went to 40 psi. I pulled the vaccum line off the regulator and it went up to 48psi. Saw no signs of fuel in vaccum line. Put a vaccum gauge on FPR and it held 5psi for over a hour. No lights and no codes. Not sure what else to try. It seems the fuel pressure is on the low end but one thread said you need 35psi to start. Note, I am in a cold climate highs 35-40 lows -10 or lower. Any ideas would be welcomed.
Old 02-10-2008, 07:28 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 95 Regal won't start after sitting
This sounds like your CTS is not operating correctly. The CTS is simply a thermosistor; as the coolant temp gets higher the resistance drops. The ECM supplies the sensor +5V and measures the voltage drop through the thermosistor to determine coolant temperature. Some resistance vs. temperature values follow:
*F--------Ohms
210----------177
158----------467
104----------1459
68------------3520
32------------9420
-4-------------28680
-40-----------100,700
The sensor is used for open/closed loop operation and is used in the calculation for fuel and ignition. (Operates like a choke on carbureted cars of the past)
Old 02-11-2008, 10:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with HotZ28 that your problem is not fuel related. All your fuel pressure readings are well within acceptable ranges.
Do you by chance have a CEL on, and if so, have you pulled the codes?
If no CEL, then I would look into the CTS as HotZ28 suggested, or possibly a borderline bad TPS.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-11-2008, 05:44 PM
It was 5 below last night so I just unplugged the sensor. Car started right up. There was anti freeze leaking on top of it so I did the intake manifold today and replaced the sensor at the same time. Works great! Thanks for the help.
