93 sil, no heat
ok
the skinny: i did a motor swap on this van a year or so ago, with the help of some folks on here, it went ok. everything functions as it should, van does not over heat, and runs at a good temp. since its been winter, there has been zero heat. it has electronic controls for the heater, unlike my vw which is controlled by a valve when you turn the heat higher. what could some problems be? ive replaced the water pump, and the thermostat. the fuse tests good. is there a relay somewhere? is there something im over looking? on a vw, its not like this, and im a vw tech, not a olds tech. any help would be greatly appreciated. thanks
Let the fools have their tartar sauce. |
Re: 93 sil, no heat
plugged heater core? hoses on the right way? no kinks. or a computer reset. just some ideas for you. 463
Re: 93 sil, no heat
Re: 93 sil, no heat
make sure the actuator on the passenger side dash is working.actually under the dash.....
Re: 93 sil, no heat
what would that look like, and whats the best way to get to it?
