Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-10-2008, 12:23 PM
ccp72 ccp72 is offline
01 Impala Starting Problems
Hi all,
I have a '01 Impala that will not start when I turn the key - no clicking, nothing. I replaced the battery, and still nothing.
I can, however start the car if I have a friend disconnect the pos. cable from the battery, turn key to "on" and touch cable to battery. This sometimes takes two or three tries.
Could this be a passkey issue or a BCM issue?
Any feedback would be greatly appreciated.
Thanks.
Old 02-10-2008, 06:19 PM
Gems Gems is offline
Re: 01 Impala Starting Problems
Probably a bad ignition switch...
Go Mark Martin!
Old 02-17-2008, 07:12 AM
AccoustikNoyz AccoustikNoyz is offline
Mine is an 03, but I wrestled with starting issues same exact symptom on about 3 occasions. 1st time it happened at the mall. I found the "crank relay" under the hood inside the black electrical panel, unplugged it and tapped in on the pavement in case it was sticking. I got it home and for several more occasions repeated the symptom and solution. It costs about$12 so I got a spare. I've seen a lot about the PCM, but when it happened again it was my starter. I was skeptical but had the old starter bench tested and the guy said, "wtf, man this thing's pegging on amps". So I guess that the two things may have been related. One year of driving with no recurrence, so I'm pleased.
Steve - Too Many Cars...not enough days off to keep 'em running.
Old 02-17-2008, 04:13 PM
j cAT j cAT is offline
Originally Posted by ccp72
Hi all,
Thanks.
never do that again unless you want to buy a new computer for your car this is a no no,,,,,,you most likely need a new starter,, because of your solution to getting the engine started i would bring to a repair shop for troubleshooting ........
