Frost on inside of windows when cold outside
On my 2004 Impala, when it's cold outside (10F or less, the colder the worse) the inside of my car windows get frost-ice on them. It doesn't matter if it's sunny out or night time. This makes visibility poor, and the ice has be be scraped off (usually not possible if it's sub-zero, and also it comes back when driving) as the car defrost doesn't do much to clear it. My old 1993 Corsica would do pretty much the same thing. Any advise is appreciated.
Re: Frost on inside of windows when cold outside
a problem I have run into with this situation is draging snow into the floor boards/carpet or the windows are leaking and water is getting the carpet wet and then the warm air evaporating it and causing this to happen.
just a thought. |
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
No hot beverages, no heavy breathing, no water leak - but thanks for those ideas thus far. The worst of the problem is the side windows, as the defrost/heat on full-blast doesn't thaw them, except only right by the side mirrors. Some snow does get tracked in (I live in Minnesota), but I see many other cars in my daytime work parking lot whose windows after work aren't covered with ice on the insides like my Impala. I can basically take my car out of my garage (not a heated garage, but attached to house) to the street on a below zero night and the clear windows will frost up on the insides while watching them. It makes the car's blind spots much larger / more dangerous.
I am the owner of a 2000 Deville and am having the exact same symptoms with my car. I took it to a dealer and had the heater core checked and it checked out OK. There is no visible sign of moisture in the car or place where moisture could get in. I am stumped. I have to keep the windshield defrost blowing on high to keep the windsheild clear but all of the side windows are completed frosted over after about 10 minutes of driving. The car sits in a heated garage and starts out fine but within a few minutes begins to frost up. I'll keep watching this post in hopes to get some ideas. Thanks for posting.
another possibility is the doors drain holes plugged. if water is trapped inside door this would cause this problem..... |
there is something wrong here!!! if it were me & ran out of ideas. i'd stop by the local dealer.hopefully the car is all iced up ask them to go for a ride.
ASK THEM TO DRIVE!!! good luck |
I set the heater/defost all the way hot/red, with fresh air intake (not recirculated), but that doesn't thaw the side windows.
I have not heard of "door drain holes", I will have to take a look for them (but I doubt that's an issue here). I could take it to the dealer, but it would have to work out that I'm able to do that on the same day that it's very cold out. I think it's tracked-in melted snow turning into humidity, but not sure "how to get it out of the car"??? |
I think your recirc door may be stuck in recirc- even though it is commanded back to outside air- I know for a fact that recirc does exactly as you describe- will fog up the windows to the point you have to pull over-I then look at the recirc door- and it is stuck in recirc. test this theory by listening to the air flow- it should change dramatically as you go from outside air to recirc and vice versa- if no changes are detected- the door is not moving and is stuck in recirc- or inside air mode.....been there--- seen that
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
My first thoughts when I read the original post was there is moisture infiltrating the interior of the vehicle somewheres. In the past I've seen situations where there was a pin hole leak in the heater core, a bad gasket/seal around a door or window, as stated before the importation of snow/ice from our boots. But you say that this isn't the first vehicle you have had this issue with which makes it even harder to diagnose.
I'm having the same problem. Wierd part of my problem is it only happens on the drivers side. I'm not sure if that means anything like the driver's door is leaking or the windshield is leaking on the driver's side. I swore I heard excess wind noise when I was driving home yesterday coming from the driver's side dashboard. It's the winter here right now, and it's a pretty bad winter at that. I took my car to the car wash and got it washed good, then opened and closed all the windows and sunroof to make sure they were sealed and closed good.
I went to the dealer and they said all they could do is run a waterhose over the car and look for any visible leaks. I have a feeling that a hole barely bigger than a pinhole in the dash around the window could cause this, and when they spray this water and a half a drop of water drips inside the dash, how are they ever going to see it? Last summer too, I took my car to the shop for another reason. My car fogged up in the windows right up the driver side window and the tech looking at my car commented that it looked wierd the way my window fogged up. I have a feeling this plays into the problem I'm having. I'm hoping there's a trick of the trade to find an air leak in a car. |
