Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-10-2008, 08:15 AM
jv117v2 jv117v2 is offline
wierd grinding from pass. side (in dash)
i have a '00 GT and it makes a grinding noise from what sounds like the dash on the pass. side when i first take off, when i shift and the rpms drop, and when im accelerating between 2 & 3 thousand rpms. dont know if its a pump (which i cant find one in that area) cv, or strut. please help !!! that and the TOB sux like everyone elses on here (causing slipping) want to know if exedy clutch is worth a shit, im guessing the one im looking at performs like stock.
Old 02-12-2008, 12:31 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: wierd grinding from pass. side (in dash)
is it a grinding or a squeaking? If it's squeaking then it might be motor mounts, otherwise it could be a lot of things. CV joints, axel, hub, control arm...you name it with drivetrain and it could be a problem.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 02-17-2008, 07:59 AM
its like a grinding/ticking noise. ive just bought 4 gabriel struts and skunk2 springs, hopefully that will help a bit. might as mod while im down there. also got exedy clutch. let me know what you think kit could be.
